[Help] Scanline Sync doesn't limit fps?
Hi! So I wanted to try out Scanline Sync in RTSS but I can't get it to work. No matter what I do I can't seem to get Scanline Sync to limit my fps. It's always unlimited as I've disabled all other types of fps limiters. Any Ideas?
Re: [Help] Scanline Sync doesn't limit fps?
Maybe you experience the same bug as I do.
Put something like -100 in Scaline Sync field (don't remember it's name, basically the field below fps)
Enable OSD
Somehow it doesn't work for me if I have OSD disabled. You can also move the OSD below the screen as a workaround if you don't want to see it
Or alternatively update Afterburner/RTSS to see if it is fixed in newer versions
Enable OSD
