Max_hz wrote: ↑08 Aug 2020, 10:00
Quarksie wrote: ↑08 Aug 2020, 07:32
@ IIISLIDEIII where did you get those charts?
According to these then the Acer Predator XB273Xbmiprzx, 27" is the fastest IPS on the market right now, is it true? can someone else confirm?
If I'm not wrong those are the charts from @ RLCSContender.
Until he can give more certainty I take his test-results with a "grain of salt".
Also read Chief Blur Buster comment about his "Lag Measurement Methodology" ;
viewtopic.php?f=2&t=6666&start=700
but in fact everyone must choose based on what he deems most appropriate, I simply gave an opinion, so in the end that it is a 240hz branded Asus, Acer or Msi, the panels are always the same and the differences will be in the order of imperceptible, certainly there is that the Asus has excellent performance only when you risk pushing the framarate to 280fps, below the performance drops dramatically, which happens to a lesser extent both on acer and on msi, if I were to evaluate an alternative to my predator I would go on MSI, certainly not on ASUS, but it's just my opinion and it applies to me.
If someone is looking for something really "different" from the whole array of 240hz IPS that there are on the market they must go only on one panel, the Benq XL2546s, beware, not said better, I said "different".
what I can guarantee based on my tests, as owner of an Lg panel with 2.2 ms input lag, is that the predator is much faster
