Just got my VG259QM, adaptive sync off, elmb sync on, the screen is still so damn bright and I'm able to control the brightness still? didn't know I can do that, I put it to around 40 with elmb and it's so much brighter than my MSI MAG.
Tested some OD 80 and OD 120, and 120 is definitally better though playing fast paced shooters I'm not noticing much issues with OD 80, dark maps I can notice some, not horrible but it's there, sure it's ugly on the ufo test but in game it's not so bad yet from my short testing.
isnt the OD setting locked when the backlight strobing (ELMB) is enabled? thats what every review of 259qm and 279qm says at least ?Stevie66 wrote: ↑17 Sep 2020, 13:41Just got my VG259QM, adaptive sync off, elmb sync on, the screen is still so damn bright and I'm able to control the brightness still? didn't know I can do that, I put it to around 40 with elmb and it's so much brighter than my MSI MAG.
It is locked. Once you enable ELMB, overdrive adjustment is unavailable. I think Stevie meant that he just tested overdrive settings outside of ELMB.alexander1986 wrote: ↑18 Sep 2020, 05:07isnt the OD setting locked when the backlight strobing (ELMB) is enabled? thats what every review of 259qm and 279qm says at least ?Stevie66 wrote: ↑17 Sep 2020, 13:41Just got my VG259QM, adaptive sync off, elmb sync on, the screen is still so damn bright and I'm able to control the brightness still? didn't know I can do that, I put it to around 40 with elmb and it's so much brighter than my MSI MAG.
Main display (TV/PC monitor): LG 42C21LA (4K 120 Hz OLED / WBE panel)
Tested displays: ASUS VG259QM/VG279QM [favourite LCD FPS display] (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell S3222DGM [favourite LCD display for the best blacks, contrast and panel uniformity] (165 Hz VA) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (graphite, fully loaded, size C)
alright, well it would be nice to hear some feedback on how bad/noticeable the strobing crosstalk is with ELMB on (no elmb-sync just elmb) in games at 240 fps/240 hz or 280 fps/280 hz, like FPS games or sports games like FIFA , would be very appreciated !
Never said I changed the OD with elmb, but the brightness.alexander1986 wrote: ↑18 Sep 2020, 05:07isnt the OD setting locked when the backlight strobing (ELMB) is enabled? thats what every review of 259qm and 279qm says at least ?Stevie66 wrote: ↑17 Sep 2020, 13:41Just got my VG259QM, adaptive sync off, elmb sync on, the screen is still so damn bright and I'm able to control the brightness still? didn't know I can do that, I put it to around 40 with elmb and it's so much brighter than my MSI MAG.
Played some shooters with elmb on at 240hz and it's pretty damn good, I probably prefer it to the MSI MAG but mostly because it's still bright and the MSI MAG got too dark
you don't see any obvious crosstalk at all at either 240 hz or 280 hz with elmb? sounds good if so !Stevie66 wrote: ↑18 Sep 2020, 10:02Never said I changed the OD with elmb, but the brightness.alexander1986 wrote: ↑18 Sep 2020, 05:07isnt the OD setting locked when the backlight strobing (ELMB) is enabled? thats what every review of 259qm and 279qm says at least ?Stevie66 wrote: ↑17 Sep 2020, 13:41Just got my VG259QM, adaptive sync off, elmb sync on, the screen is still so damn bright and I'm able to control the brightness still? didn't know I can do that, I put it to around 40 with elmb and it's so much brighter than my MSI MAG.
Nope don't notice any, but that doesn't mean you won't but if I can notice some corona in gaming at OD80 in some dark scenes I guess my eyes would be able to notice crosstalk with elmb. I see it in the ufo test but not in game unless I stand still and really look for it moving the mouse around I might notice something slight maybe? I do notice it if I'm playing a game where the fps is lower than the target elmb hz though but that's understandable.alexander1986 wrote: ↑18 Sep 2020, 10:18you don't see any obvious crosstalk at all at either 240 hz or 280 hz with elmb? sounds good if so !Stevie66 wrote: ↑18 Sep 2020, 10:02Never said I changed the OD with elmb, but the brightness.alexander1986 wrote: ↑18 Sep 2020, 05:07isnt the OD setting locked when the backlight strobing (ELMB) is enabled? thats what every review of 259qm and 279qm says at least ?Stevie66 wrote: ↑17 Sep 2020, 13:41Just got my VG259QM, adaptive sync off, elmb sync on, the screen is still so damn bright and I'm able to control the brightness still? didn't know I can do that, I put it to around 40 with elmb and it's so much brighter than my MSI MAG.
cool ty for the feedback mate !Stevie66 wrote: ↑18 Sep 2020, 10:27Nope don't notice any, but that doesn't mean you won't but if I can notice some corona in gaming at OD80 in some dark scenes I guess my eyes would be able to notice crosstalk with elmb. I see it in the ufo test but not in game unless I stand still and really look for it moving the mouse around I might notice something slight maybe? I do notice it if I'm playing a game where the fps is lower than the target elmb hz though but that's understandable.alexander1986 wrote: ↑18 Sep 2020, 10:18you don't see any obvious crosstalk at all at either 240 hz or 280 hz with elmb? sounds good if so !Stevie66 wrote: ↑18 Sep 2020, 10:02Never said I changed the OD with elmb, but the brightness.alexander1986 wrote: ↑18 Sep 2020, 05:07
you dont happen to have FIFA installed or would be willing to download the demo ? or some similar sports game like NHL or so, to see if there is any obvious crosstalk in these sports games? totally understandable if not but hey worth asking tnx again either way !
Played some PES 2020, slow game so probably harder to notice things instead of fast paced movement games, noticed no crosstalk at 280hz elmb onalexander1986 wrote: ↑19 Sep 2020, 07:51cool ty for the feedback mate !Stevie66 wrote: ↑18 Sep 2020, 10:27Nope don't notice any, but that doesn't mean you won't but if I can notice some corona in gaming at OD80 in some dark scenes I guess my eyes would be able to notice crosstalk with elmb. I see it in the ufo test but not in game unless I stand still and really look for it moving the mouse around I might notice something slight maybe? I do notice it if I'm playing a game where the fps is lower than the target elmb hz though but that's understandable.alexander1986 wrote: ↑18 Sep 2020, 10:18you don't see any obvious crosstalk at all at either 240 hz or 280 hz with elmb? sounds good if so !
sweet! ty tyStevie66 wrote: ↑19 Sep 2020, 10:58Played some PES 2020, slow game so probably harder to notice things instead of fast paced movement games, noticed no crosstalk at 280hz elmb onalexander1986 wrote: ↑19 Sep 2020, 07:51cool ty for the feedback mate !Stevie66 wrote: ↑18 Sep 2020, 10:27Nope don't notice any, but that doesn't mean you won't but if I can notice some corona in gaming at OD80 in some dark scenes I guess my eyes would be able to notice crosstalk with elmb. I see it in the ufo test but not in game unless I stand still and really look for it moving the mouse around I might notice something slight maybe? I do notice it if I'm playing a game where the fps is lower than the target elmb hz though but that's understandable.alexander1986 wrote: ↑18 Sep 2020, 10:18
