Native (plug-and-play) 8000hz mouse
Posted: 25 Aug 2020, 08:34
https://atompalm.com/
• due for release in fall 2020
• uses a USB Hi-speed microcontroller to allow for native (non-overclocked) 8000hz polling
• uses some kind of special debouncing circuit to remove debounce delay from switches. Should have the lowest input delay of any mouse (perhaps on par with the Zaunkoenig M1K, which has 3-pin debounce)
• 45 grams
• corded
• PMW3360
• Japanese gold-cladded omrons (D2F-01F) - big-company mice use Chinese brass-cladded omrons
• anodized aluminum scroll wheel
This is the only mouse of its kind, there are zero other USB Hi-speed mice.
Should immediately work at 8000hz after plugging it in. No overclocking needed.
For information on above-1000hz mouse polling (does it make a difference etc.,) see:
Chief Blur Buster's article on the matter
Chief Blur Buster's post on the matter
my thread on the matter
• 45 grams
• corded
• PMW3360
