im looking for a way to see the ingame monitor refresh rate in hertz. some monitors can show this via the monitor menu, but not all
and remember, im not looking for a tool like fraps, because it shows framerate, not monitor refresh rate
frame rate : the number of frames being sent from a computer
refresh rate : how often a monitor is updating its picture
App or method for seeing ingame refresh rate?
Re: App or method for seeing ingame refresh rate?
The monitor will run at the Hz you selected in Windows or the GPU driver panel. Unless you want a VRR indicator (freesync or gsync). There are no tools for that, and there can't be. This is something the monitor itself needs to be able to report.
If on the other hand you want to know the exact refresh rate of the currently selected mode to several decimal places, then you can use one of the refresh rate detectors, like:
https://www.testufo.com/refreshrate
Steam • GitHub • Stack Overflow • Twitter
You can use fraps if you freesync/gsync but apart from that I don't believe there is a program for that.
