Gigabyte Aorus FI25F (0.4ms MPRT 240hz IPS monitor)
fullsender
Re: Gigabyte Aorus FI25F (0.4ms MPRT 240hz IPS monitor)
Post by fullsender » 26 Mar 2021, 09:35
Does anyone actually have this? Is it good and is it better than monitors like VG259qm and maybe the new VG258qm? Theres a sale going on and this monitor is only $25 more expensive than the VG259qm. I play games like CSGO and competitive performance is really important for me.
UNKKit
Post by UNKKit » 13 Apr 2021, 11:23
Very interested in this monitor because of the user customizable crosshairs. From this review, https://www.tomshardware.com/reviews/gi ... tor-review, the monitor is so bright using ULMB with it's 30% reduction will not be an issue.
Alienware AW2521H (main) |Acer XF252QX |5600x |3080 |3600CL16
UNKKit
Post by UNKKit » 15 Apr 2021, 12:05
I just ordered monitor from Amazon and will be able to give my thoughts on it next week.
Nm_kng
Post by Nm_kng » 25 May 2021, 15:26
UNKKit wrote:
15 Apr 2021, 12:05
Sooo, what do you think of it?
VG259QM (MAIN) | XL2546K | Aorus KD25F
UNKKit
Post by UNKKit » 26 May 2021, 09:28
It has an amazing user customizable crosshair but otherwise was no better than my Acer XF252QX. I've returned it and upgraded to the Alienware AW2521H 360hz monitor which I'm keeping.
Nm_kng wrote:
25 May 2021, 15:26
Nm_kng
Post by Nm_kng » 28 May 2021, 19:41
UNKKit wrote:
26 May 2021, 09:28
Nm_kng wrote:
25 May 2021, 15:26
Oh nice. I got an KD25F today, but definitely returning it cause the guy who I bought it told me he only used it for 2 months. Turns out it’s been used for a year and it has a lot of scratches. Probably getting an VG259QM soon.
XERP
Post by XERP » 01 Jun 2021, 04:13
Hi all! First sorry for my bad english. Yesterday i received this monitor FI27Q-X. I have to say that I come from an asus PG279Q @ 165hz and the change has been remarkable in terms of motion blur.
Edit: Wow, I got confused thinking it was the same model, I have noticed that they are of a different size, but are they the same panel?
Paulk1994
Post by Paulk1994 » 03 Jun 2021, 00:02
fullsender wrote:
26 Mar 2021, 09:35
I had the aorus for 2 weeks... it was okay. I had previously returned the VG259qm because I wasn’t sure if it was the best choice. Turns out it was a mistake and the VG259qm was way better then my experience on the aorus.
