Gigabyte Aorus FI25F (0.4ms MPRT 240hz IPS monitor)
purplew
Post by purplew » 08 Sep 2020, 16:31
Does anyone own one of these? They're newly released and use propriety tech to achieve 0.4ms MPRT..
https://www.gigabyte.com/Monitor/AORUS-FI25F
Re: Gigabyte Aorus FI25F (0.4ms MPRT 240hz IPS monitor)
Post by Chief Blur Buster » 08 Sep 2020, 16:55
purplew wrote:
08 Sep 2020, 16:31
Low MPRT is easy by pulse width adjustment -- NVIDIA ULMB Monitors have achieved as low as 0.25ms MPRT or thereabouts.
The biggest problem is cramming maximum lumen per microsecond to get the low-MPRT as bright as possible, through careful voltage-boosting of a strobe backlight mode. (LEDs can be overdriven about 2x-5x current when briefly pulsed)
speancer
Post by speancer » 08 Sep 2020, 17:11
Chief Blur Buster wrote:
08 Sep 2020, 16:55
purplew wrote:
08 Sep 2020, 16:31
So, basically "0.4 ms response time" is just a marketing slogan, and it only applies to strobing?
Main display (TV/PC monitor): LG 42C21LA (4K 120 Hz OLED / WBE panel)
Tested displays: ASUS VG259QM/VG279QM [favourite LCD FPS display] (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell S3222DGM [favourite LCD display for the best blacks, contrast and panel uniformity] (165 Hz VA) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (graphite, fully loaded, size C)
purplew
Post by purplew » 08 Sep 2020, 17:15
08 Sep 2020, 16:55
purplew wrote:
08 Sep 2020, 16:31
Thanks for the reply, but as @speancer asks, does this mean it wouldn't perform better than current 240hz IPS monitors just on the 0.4ms number alone?
Stevie66
Post by Stevie66 » 08 Sep 2020, 17:16
1ms is also marketing slogan as I've never seen a monitor hit 1ms average
purplew wrote:
08 Sep 2020, 17:15
08 Sep 2020, 16:55
purplew wrote:
08 Sep 2020, 16:31
When it's tested and if it's better than the others then it will, be if not then it won't. As you can see 1ms 240hz response times can vary a lot with current monitors. Some are better than others.
Post by Chief Blur Buster » 08 Sep 2020, 17:39
Correct.
MPRT less than refreshtime requires the use of a strobe backlight.
See Pixel Response FAQ: GtG versus MPRT
It explains how GtG and MPRT numbers are calculated.
GtG is pixel transition time, more responsible for ghosting/corona effects but can add extra blur when slow.
MPRT is pixel visibility time, directly proportional to visible display motion blur.
The only way to get low MPRT without strobing (1ms MPRT) is 1000fps at 1000Hz. See Blur Busters Law: The Amazing Journey To Future 1000Hz Displays.
purplew
Post by purplew » 08 Sep 2020, 17:55
08 Sep 2020, 17:39
Correct.
I get it now. So it's just marketing of their ULMB method. Thanks
RLCSContender*
Post by RLCSContender* » 08 Sep 2020, 17:59
that 100% srgb and 24.5" is intriguing and i will definitely buy this. If 100% srgb checks out and the pixel response time doesn't overshoot on its optimal overdrive setting, this would be a keeper for me.
'-'@_
Post by '-'@_ » 19 Sep 2020, 22:06
Gigabyte also has one of the best OSDs on the market. Will be interesting to see how this one stacks up against VG259QM and MAG251RX etc.
'-'@_
Post by '-'@_ » 08 Dec 2020, 06:25
This monitor has now been out for a couple of months, but still no reviews in sight. Did anyone try this monitor?
