Page 1 of 2
Gigabyte Aorus FI25F (0.4ms MPRT 240hz IPS monitor)
Posted: 08 Sep 2020, 16:31
by purplew
Does anyone own one of these? They're newly released and use propriety tech to achieve 0.4ms MPRT..
https://www.gigabyte.com/Monitor/AORUS-FI25F
Re: Gigabyte Aorus FI25F (0.4ms MPRT 240hz IPS monitor)
Posted: 08 Sep 2020, 16:55
Low MPRT is easy by pulse width adjustment -- NVIDIA ULMB Monitors have achieved as low as 0.25ms MPRT or thereabouts.
The biggest problem is cramming maximum lumen per microsecond to get the low-MPRT as bright as possible, through careful voltage-boosting of a strobe backlight mode. (LEDs can be overdriven about 2x-5x current when briefly pulsed)
Posted: 08 Sep 2020, 17:11
by speancer
Chief Blur Buster wrote: ↑08 Sep 2020, 16:55
So, basically "0.4 ms response time" is just a marketing slogan, and it only applies to strobing?
Posted: 08 Sep 2020, 17:15
by purplew
Thanks for the reply, but as @speancer asks, does this mean it wouldn't perform better than current 240hz IPS monitors just on the 0.4ms number alone?
Posted: 08 Sep 2020, 17:16
by Stevie66
1ms is also marketing slogan as I've never seen a monitor hit 1ms average
purplew wrote: ↑08 Sep 2020, 17:15
When it's tested and if it's better than the others then it will, be if not then it won't. As you can see 1ms 240hz response times can vary a lot with current monitors. Some are better than others.
Posted: 08 Sep 2020, 17:39
Correct.
MPRT less than refreshtime requires the use of a strobe backlight.
See Pixel Response FAQ: GtG versus MPRT
It explains how GtG and MPRT numbers are calculated.
GtG is pixel transition time, more responsible for ghosting/corona effects but can add extra blur when slow.
MPRT is pixel visibility time, directly proportional to visible display motion blur.
The only way to get low MPRT without strobing (1ms MPRT) is 1000fps at 1000Hz. See
Blur Busters Law: The Amazing Journey To Future 1000Hz Displays.
Posted: 08 Sep 2020, 17:55
by purplew
I get it now. So it's just marketing of their ULMB method. Thanks
Posted: 08 Sep 2020, 17:59
by RLCSContender*
that 100% srgb and 24.5" is intriguing and i will definitely buy this. If 100% srgb checks out and the pixel response time doesn't overshoot on its optimal overdrive setting, this would be a keeper for me.
Posted: 19 Sep 2020, 22:06
by '-'@_
Gigabyte also has one of the best OSDs on the market. Will be interesting to see how this one stacks up against VG259QM and MAG251RX etc.
Posted: 08 Dec 2020, 06:25
by '-'@_
This monitor has now been out for a couple of months, but still no reviews in sight. Did anyone try this monitor?
