Official Asus ROG Swift 360Hz PG259QN Owners Thread
I know. So my first thought is: If I have the special mouse for it, so I can make settings/tweaks on my PC and check it with my mouse if the latency is higher or less. So it could give me the "power" of optimzing my system perfectly for the minimal latency. Or is it just a test, based on my GPU?
Watch the video on it it should give you more info, sounds like its for people that would easily just swap out their GPU CPU RAM etc and keep testing to find the lowest delay possible, I don't see a point of spending all this extra money for probably 1-3ms at the most unless you are making good money off esports.
My apologies. I haven't tested ULMB yet. Mainly due to the fact its limited to 240hz. I had to get some content out there yesterday so that slowed me down on test. I've disabled GSync and have latest drivers and still not able to turn on ULMB. Reducing refresh rate to 240hz its still not an option.
Regarding sales, I was checking with extreme frequency and preordered shortly before BH pulled them to back order the day it showed only to move to preorder a few days later. I would never order from NewEgg and hadn't seen on Amazon at all. My Microcenter had the SKU show up a 2 days prior to one landing locally. The store only had 2 total and its extremely busy. I was surprised I managed to grab it as it was listed within 1 hour of checking the day I grabbed it. I just got lucky as I had the page on my MAC at the table and refreshed on opening. Best of luck. It is truly amazing display.
How does this monitor perform on 60fps locked games with VRR disabled, like Street Fighter V? I know allot of 240Hz monitors suffer from input lag at 60Hz so I’m just wondering if this monitor is in the same boat
if its good at 60fps locked im buying this 1 million percent
I do not own any 60FPS locked games though I could cap a game at 60fps and test.. I did see in Hardware Unboxed Review they show a 4.39 GTG @ 60hz but I am not sure how to gauged their input lag chart. Input lag being the fastest they've measured but maybe that is highest refresh rate. They show processing lag, processing + refresh lag, processing, refresh, and response. https://youtu.be/tsB9G4eRokU?t=493 not sure if VRR is running..kernel 0x000 wrote: ↑29 Sep 2020, 03:12How does this monitor perform on 60fps locked games with VRR disabled, like Street Fighter V? I know allot of 240Hz monitors suffer from input lag at 60Hz so I’m just wondering if this monitor is in the same boat
I have not been able to disable VRR either quite honestly. There just isn't enough hours in the day. I played around dropping the refresh but simply could not get ULMB to work. I could not find a VRR option in the menu and ULMB is greyed out. I did see the online English Manual was updated https://dlcdnets.asus.com/pub/ASUS/LCD% ... nglish.pdf but even lowering refresh rate via NVCP and Windows ULMB was greyed out. I'll let you know when I dig into this more.
Just wait for a Rtings review, they always test the input lag at max and 60hz. I think Tftcentral does too if I recall, and their review is out for the public in a few days.
awesome, thanks for the responses so far, I will be waiting for the Rtings review then
i have a vg259qm. not sure whether should i upgrade to the pg259qn. Will i see a noticeable improvement? Mainly just playing csgo
No one can really tell you that, it's subjective. Buy it, try it out, return it if you're not convinced. Some people don't even notice or hardly notice a difference between 144 Hz and 240 Hz. I would not expect miracles or any major change, because as refresh rate gets higher, it's also progressively harder to notice the difference. Also, you need super high frame rate to match that 360 Hz refresh rate. It's doable in e-sport titles like CS:GO, of course. Response times are also not so far apart between these two ASUS displays.jnashville wrote: ↑30 Sep 2020, 04:19i have a vg259qm. not sure whether should i upgrade to the pg259qn. Will i see a noticeable improvement? Mainly just playing csgo
There's 0.79ms less total processing lag on PG259QN thanks to its 360 Hz refresh rate (280 Hz scanout: 3.57 ms, 360 Hz scanout: 2.78 ms) when compared to VG259QM. Do you think you could tell the difference? VG259QM and VG279QM already have incredibly low input lag (below 2 ms for both). I want to test PG259QN myself, but it's gonna be too expensive, I'm afraid. I would argue if the price difference justifies performance difference between VG259QM and PG259QN.
Also remember that to fully utilize PG259QN in competitive setting, you should always have around 360 fps in-game, or at least be as close to this figure as possible. You could of course just use G-SYNC as well, especially if you're not really hitting that super high fps to utilize 360 Hz, at this refresh rate there's basically no lag difference between G-SYNC and V-SYNC OFF that would matter, at least from what I've been told by Blur Busters representative - jorimt.
Main display (TV/PC monitor): LG 42C21LA (4K 120 Hz OLED / WBE panel)
Tested displays: ASUS VG259QM/VG279QM [favourite LCD FPS display] (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell S3222DGM [favourite LCD display for the best blacks, contrast and panel uniformity] (165 Hz VA) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (graphite, fully loaded, size C)
