Hello, I have a problem. On fps 130-180 i have tearing, the picture is not smooth in the game pubg. But only on 1 map on Miramar, on other maps with this fps everything looks smooth. What is the problem?
Omen x25 240 hz tearing
Xl 2546
Re: Omen x25 240 hz tearing
My guess would be you're using nVidia Gsync incorrectly or AMD's FreeSync incorrectly. It's worth asking if this just started?
If you don't use g-sync or vsync, you will get tearing. That's normal.
Is it normal that with g sink I get a blur when the fps is less than 120?
Xl 2546
Lower FPS means more blur, but that should also be true without g-sync.
Have you tried changing the overdrive setting in the monitor's OSD? Also, is this the X 25 native g-sync model, or the X 25f g-sync compatible one?
This is native g sync.
How can I check for blurring? I think it worked better before, I turned g sync on and off too often in nvcp, could it break because of this?
Should there be less blur with g sync?
Xl 2546
No.
It should be the same amount of blur as without g-sync. Can you test with 100Hz if the monitor supports that, and without g-sync? Do you see the same amount of blur then as with 100FPS at 240Hz with g-sync?Should there be less blur with g sync?
I enabled and disabled g sync in menu nvcp. Not in the nvcp app settings. A lot of times
Xl 2546
I think it always looks the same maybe I'm wrong.100 hz with 100fps without g sync and 240 hz with 100 fps and g sync. Same, but maybe im wrong
Xl 2546
