Hello,
I plan on a new PC build, waiting on 3070 or 3080 so could be waiting till 2021 before that's ready. In meantime I'm using my PS4 pro. Id like to buy a 240hz monitor now and use with the PS4 then be ready when switching to PC. I saw the XG258Q mentioned is good for 60 and 240 but it seems to no longer be available.
I have been researching for days on Reddit and here, problem is every model seems out of stock.
-Will be in basement-light controlled
-Standard desk setup, looking 24"
-Budget 400ish
-FPS shooter games
Any suggestions? TIA
Help finding 240hz monitor, PC and PS4
Re: Help finding 240hz monitor, PC and PS4
Looking at rtings measurements
its seems the AW2521HF has lowest input lag for 240 and 60. Does that seem correct?
For the PS4, Do I want to refer to 'Input Lag Native Resolution @ 60hz' or 'Input Lag variable Refresh Rate @60hz'?
