hi
i am searching for a 1080p monitor that support the next gaming consoles 120hz and freesync together
but not sure what is the specification of the monitor should be
a little bet confused cause there is a different types of freesync and hdmi
FreeSync
FreeSync Premium
FreeSync Premium Pro
hdmi 2.0 and 2.1
iam a little bet confused and not sure which gaming monitor well work well with 120hz and freesync together
or just pick up any cheap freesync monitor support it well work well with it ?
please need help
thanks
need help to get a 1080p monitor for the next gaming consoles support 120hz and freesync
Re: need help to get a 1080p monitor for the next gaming consoles support 120hz and freesync
https://www.amd.com/en/technologies/free-sync
Acer Nitro XV273X 27" Flat IPS 1080p 240Hz, support FreeSync over HDMI 2.0, around 400$. https://www.tftcentral.co.uk/reviews/ac ... xv273x.htm
HDMI 2.0 is enought for 1080p120, 2.1 is for 2160p120.
If you want low lag, LFC and HDR, get one Premium Pro certified.
If the priority is Black/Contrast/HDR, LG OLED CX 48" 4K 120Hz HDMI 2.1 FreeSync Premium Pro, better than any monitor. It can work also at 1080p. Also has motion blur reduction without crosstalk. Expensive, but amazing ! Sadly is not available at lower size.
https://www.tftcentral.co.uk/reviews/lg_cx_oled.htm#mbr
https://www.youtube.com/watch?v=wUWXPvdm42I
Acer Nitro XV273X
(freesync) well work with ps5 ?
