On all resolutions, tried many settings in monitor and all the time the same, i think it's not normal. When i am moving around in game everything is a bit darker.
https://streamable.com/jwyyol
Omen X 25f issue - Vertical black lines.
Re: Omen X 25f issue - Vertical black lines.
Pixel inversion most likely.
Does it look different on different framerates?
Have you tested for inversion artifacts on testufo and lagom.nl? If you get flicker there it's normal, but how it flickers might give an idea of the cause of those lines.
That's your typical high refresh rate TN panel experience, with terrible pixel inversion artifacts, because that's how we call what you see. From my experiences, this phenomenon is fairly common in high refresh rate TN panels. I have previously seen a complaint about Omen X 25f inversion artifacts issue, and I experienced it myself, as you can read in here.
Actually, the very first high refresh rate TN monitor that does not suffer from pronounced pixel inversion artifacts for me is the newest BenQ Zowie XL2546K, surely the best TN monitor I tested so far.
I advice you return your Omen X 25f and either try your luck with another unit, or choose something else entirely. You do not necessarily have to rely on TN panels for good gaming performance anymore, new-gen 240 Hz IPS (and 360 Hz IPS) panels are really good options these days as well, and they offer better overall viewing experience with better colour performance and wide viewing angles. There are plenty of discussions about these monitors around here!
Main display (TV/PC monitor): LG 42C21LA (4K 120 Hz OLED / WBE panel)
Tested displays: ASUS VG259QM/VG279QM [favourite LCD FPS display] (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell S3222DGM [favourite LCD display for the best blacks, contrast and panel uniformity] (165 Hz VA) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (graphite, fully loaded, size C)
