Hi,
I can get 10 bit mode to work with my 5700 XT card on the Asus VG259QM via displayport no problem at 144hz but cant get past 8bit mode at 240hz. Tried using CRU. While running at 240hz mode I double clicked the ' "Detailed resolution" of 1920x1080 @ 60hz' and selecting reduced lcd and then ok and ok. Then Restart64. Nothing changes. Radeon driver panel will still not enable 10 bit mode. Am I using CRU correctly?
Thanks
Asus VG259QM 240hz 10bit trick not working
Re: Asus VG259QM 240hz 10bit trick not working
If you say "30-bit color depth", unfortunately this doesn't support your monitor (up to only 16.8 million colors). But try any CRT monitor for work 30-bit color - we remember infinite colors.
CPU: [email protected]
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC new! <3
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 21" Sony E530
HDD: SATA 1TB
nuninho1980 wrote: ↑25 Dec 2020, 19:29If you say "30-bit color depth", unfortunately this doesn't support your monitor (up to only 16.8 million colors). But try any CRT monitor for work 30-bit color - we remember infinite colors.
I never said "30-Bit". Its "10-Bit". Not 30-bit.
Referring to this:
https://forums.blurbusters.com/viewtopic.php?f=2&t=7414
I feel stupid. Was connected via HDMI. Probably because my Occulus VR headset required HDMI.
