Should I get the xl2411k?
Should I get this monitor? I play mostly Hunt Showdown and Tarkov is it worth the 300$ or should I get something else?
Re: Should I get the xl2411k?
[Edited topic text to more descriptive text]
It depends on your priorities, how professional you are, and what you're upgrading from, and what you currently use.
The XL2411 and XL2546 series are very common esports monitors.
Also, be warned XL2411K does not support single-strobe like XL2411, XL2411Z, and XL2411P.
At the moment I have a Asus VG278 165hz .5ms monitor and want to upgrade since the ELMB isn't really that great with the monitor. I want to get a BenQ ZOWIE XL2546K but getting that in Canada is hard right now.
Atm I have a Asus VG278 165hz .5ms Monitor. I want to get the BenQ ZOWIE XL2546K but that monitor is hard to get in Canada, debating if I should wait until one comes to market.
Did BenQ's TN panel improve in terms of colors over the years? Because I've always heard the new TN colors arent the old ones, but not sure if true
for example the BenQ XL2411T/Z/P etc, compare to todays BenQ XL2546S/K? In terms of colors purely, is there an improvement?
Unless you're making money off of esport get 24G2U
The thing is that I just want a monitor with very low motion blur and ghosting. And getting a BenQ ZOWIE XL2546K in Canada atm is kinda hard.
What did you end up getting?
