Hello.
Does the OLED TV 55" get flicker? If "no" then "blur-free" may be failed except of 1000Hz enabled to reduce motion blur. But I don't test it yet.
Regards
OLED TV 55EA970V (Europe): flicker? [For blur reduction]
CPU: [email protected]
RAM: 2x16GB DDR4@3600MHz
MB: MSI PRO Z690-A DDR4
GPU: Zotac RTX 4090 non-OC new! <3
HDD: SATA 1TB
PSU: AEROCOOL 1kW 80+ Gold
Disly: CRT 21" Sony E530
HDD: SATA 1TB
Re: OLED TV 55EA970V (Europe): flicker? [For blur reduction]
Some OLED HDTVs use black frame insertion, and I think this TV has a mode that enables it, but I am not sure if it also uses interpolation. Most sites that describe this TV are in French, but maybe you can check the TV manual for motion clarity modes that this TV uses. Flicker can appear/disappear as you adjust the motion clarity modes.nuninho1980 wrote:Hello.
Regards
