XG270 or AW2521H
Kerosine
XG270 or AW2521H
Post by Kerosine » 30 Jan 2021, 10:31
Hi everyone.
I have AW2518H. It's time to upgrade, but i can't understand what to buy.
XG270 with same 240hz but with Blurbusters Aproved Seal.
Or AW2521H with 360hz, Nvidia Reflex. But there is no info about it on Blurbusters.
Can someone solve?
mdk999
Re: XG270 or AW2521H
Post by mdk999 » 23 Jul 2021, 13:28
I'm wondering about the exact same thing. Found any answer?
Post by Chief Blur Buster » 25 Jul 2021, 02:15
While I've worked on the XG270, there are pros and cons of both monitors. Be noted that Blur Busters Approved is focussed on strobing, so if you do not use strobing, then the seal might not be important to you.
AMD certifies FreeSync, NVIDIA certifies G-SYNC, and Blur Busters certifies strobing.
