I just got the Dell Alienware AW2521HF to tide me over till I see when the Viewsonic monitors come out.
Is there any benefit to using HDMI over Display Port for 240Hz? I hear G-Sync only works on Display Port but if I don't care about that stuff is HDMI better in anyway?
Is there any benefit to Display port over HDMI in input lag or response time?
Re: Is there any benefit to Display port over HDMI in input lag or response time?
No, there is no benefit whatsoever, DisplayPort is objectively better for PC.
Main display (TV/PC monitor): LG 42C21LA (4K 120 Hz OLED / WBE panel)
Tested displays: ASUS VG259QM/VG279QM [favourite LCD FPS display] (280 Hz IPS) • Zowie XL2546K/XL2540K/XL2546 (240 Hz TN DyAc) • Dell S3222DGM [favourite LCD display for the best blacks, contrast and panel uniformity] (165 Hz VA) • Dell Alienware AW2521HFLA (240 Hz IPS) • HP Omen X 25f (240 Hz TN) • MSI MAG251RX (240 Hz IPS) • Gigabyte M27Q (170 Hz IPS) • Acer Predator XB273X (240 Hz IPS G-SYNC) • Acer Predator XB271HU (165 Hz IPS G-SYNC) • Acer Nitro XV272UKV (170 Hz IPS) • Acer Nitro XV252QF (390 Hz IPS) • LG 27GN800 (144 Hz IPS) • LG 27GL850 (144 Hz nanoIPS) • LG 27GP850 (180 Hz nanoIPS) • Samsung Odyssey G7 (240 Hz VA)
OS: Windows 11 Pro GPU: Palit GeForce RTX 4090 GameRock OC CPU: AMD Ryzen 7 7800X3D + be quiet! Dark Rock Pro 4 + Arctic MX-6 RAM: 32GB (2x16GB dual channel) DDR5 Kingston Fury Beast Black 6000 MHz CL30 (fully optimized primary and secondary timings by Buildzoid for SK Hynix die on AM5 platform) PSU: Corsair RM1200x SHIFT 1200W (ATX 3.0, PCIe 5.0 12VHPWR 600W) SSD1: Kingston KC3000 1TB NVMe PCIe 4.0 x4 SSD2: Corsair Force MP510 960GB PCIe 3.0 x4 MB: ASUS ROG STRIX X670E-A GAMING WIFI (GPU PCIe 5.0 x16, NVMe PCIe 5.0 x4) CASE: be quiet! Silent Base 802 Window White CASE FANS: be quiet! Silent Wings 4 140mm PWM (3x front, 1x rear, 1x top rear, positive pressure) MOUSE: Logitech G PRO X Superlight (white) Lightspeed wireless MOUSEPAD: ARTISAN FX HIEN (wine red, soft, XL) KEYBOARD: Logitech G915 TKL (white, GL Tactile) Lightspeed wireless HEADPHONES: Sennheiser Momentum 4 Wireless (white) 24-bit 96 KHz + Sennheiser BTD600 Bluetooth 5.2 aptX Adaptive CHAIR: Herman Miller Aeron (graphite, fully loaded, size C)
I had AW2518HF with HDMI in box, then I bought display port cabel just for test, there wasn't difference.
Versions are more important than the port type.
For example
- old HDMI versus new DisplayPort
- old DisplayPort versus new HDMI
For example
HDMI 2.1 vs DP 2.0? which advice? (no gsync) 1920x1080Chief Blur Buster wrote: ↑27 Mar 2021, 00:59Versions are more important than the port type.
For example
It's really only relevant for things like 5-10 year differences such as DP 2.0 versus HDMI 1.2 .... Where one display is using a port tech 5+ years older than the other.
Also, HDMI/DP transceiver quality matters a lot -- as well as the scaler processing attached to them -- faster processing of display micropackets in a more jitter-free manner at lower lag to tinier scanline buffers instead of full frame buffers.
And sometimes refresh rate support is hamstrung due to either transceiver limits or older cable -- e.g. lower Hz on the HDMI than DP. But many newer models of 240Hz monitors now can do 240Hz on both HDMI and DP.
