G27F Monitor settings help
ChungusSlayer1211
Post by ChungusSlayer1211 » 02 Apr 2021, 09:22
Hello,
I have recently purchased the Gigabyte G27F monitor and have noticed that there is an aimstabilizer setting along with a freesync setting. However, only one of the options can be used at a time as the other is disabled when you enable one.
The aimstabilizer option is a motion blur reducing option - similar to ULMB i think.
I want to find out which is the more optimal setting for competitive shooters or should I disable both?
