In a wide-ranging interview with others in the Pro AV space, Joel Silver talks of a 300hz waypoint on the way to retina refresh:
Worth a listen/watch.
300hz as a Target/Standarized Refresh Rate
Re: 300hz as a Target/Standarized Refresh Rate
Forum members need to have at least between 3 to 5+ posts (threshold varies) minimum to get full posting priveleges (immediate post, skip moderator queue, post links, post video embeds). This is due to the spam filter system here...
For now, if it rejects your links, just do periods instead of dots and colons. If your post goes in the queue, an admin will manually convert your links to easy clickies if the link is authorized.
Example: youtube com/watch?v=aBcDeFgHiJwhatever
Cheers,
