Sony has upped the bar with its latest flagship's display and camera.
https://www.sony.com/electronics/smartphones/xperia-1m3
This looks like an inflection point where great motion playback and capture get more emphasis than the spatial resolution.
DISPLAY RESOLUTION
4K HDR OLED (3840 x 1644)
FEATURES
120Hz Refresh rate, 240Hz Motion blur reduction, 240Hz Touch scanning rate, Creator mode "powered by CineAlta"—Inspired by Master Monitor color reproduction, DCI-P3 100%, ITU-R BT.2020 (REC.2020) [STL8K: No % coverage listed], Illuminant D65 White point, 10 bit tonal gradation, X1™ for mobile.
Video Recording
FEATURES
Cinematography Pro "powered by CineAlta," 4K HDR Movie recording 24, 25, 30, 60 and 120 fps slow-motion, OIS and EIS Video, Optical SteadyShot™ with FlawlessEye™, SteadyShot™ with Intelligent Active Mode (5-axis stabilization), Intelligent wind filter
Sony 2021 Flagship Smartphone Display
Re: Sony 2021 Flagship Smartphone Display
Again, Sony is releasing a smartphone with 4k resolution, which will only be activated in 2 cases: photo, video content.stl8k wrote: ↑15 Apr 2021, 21:56Sony has upped the bar with its latest flagship's display and camera.
DISPLAY RESOLUTION
FEATURES
Video Recording
FEATURES
Most likely 120Hz will work in full hd resolution, possibly QHD.
This and the pros of 4k are reduced to zero: since the size of the red and blue subpixels is larger (2/3 the size of green), it turns out that it is slightly ahead of full hd led / LCD in image quality.
This is not a sony xperia xz premium for you, where the screen was an LED / LCD display with honest subpixels (although it also showed 4k on video, photo content), but the ego can be set up in 5 minutes using a PC to display 4k all the time (in there is such a video in the internet)
It turns out that the display is 4K 120hz HDR coincidently.
Receipts
https://youtu.be/WBXAP3ZH2cA
https://www.youtube.com/watch?v=qIsr2SFNCG4&t=0s
Receipts
