Sony 2021 Flagship Smartphone Display
stl8k
Post by stl8k » 15 Apr 2021, 21:56
Sony has upped the bar with its latest flagship's display and camera.
https://www.sony.com/electronics/smartphones/xperia-1m3
This looks like an inflection point where great motion playback and capture get more emphasis than the spatial resolution.
DISPLAY RESOLUTION
4K HDR OLED (3840 x 1644)
FEATURES
120Hz Refresh rate, 240Hz Motion blur reduction, 240Hz Touch scanning rate, Creator mode "powered by CineAlta"—Inspired by Master Monitor color reproduction, DCI-P3 100%, ITU-R BT.2020 (REC.2020) [STL8K: No % coverage listed], Illuminant D65 White point, 10 bit tonal gradation, X1™ for mobile.
Video Recording
FEATURES
Cinematography Pro "powered by CineAlta," 4K HDR Movie recording 24, 25, 30, 60 and 120 fps slow-motion, OIS and EIS Video, Optical SteadyShot™ with FlawlessEye™, SteadyShot™ with Intelligent Active Mode (5-axis stabilization), Intelligent wind filter
valeriy l14
Re: Sony 2021 Flagship Smartphone Display
Post by valeriy l14 » 16 Apr 2021, 00:45
stl8k wrote:
15 Apr 2021, 21:56
DISPLAY RESOLUTION
FEATURES
Video Recording
FEATURES
Again, Sony is releasing a smartphone with 4k resolution, which will only be activated in 2 cases: photo, video content.
Most likely 120Hz will work in full hd resolution, possibly QHD.
This and the pros of 4k are reduced to zero: since the size of the red and blue subpixels is larger (2/3 the size of green), it turns out that it is slightly ahead of full hd led / LCD in image quality.
This is not a sony xperia xz premium for you, where the screen was an LED / LCD display with honest subpixels (although it also showed 4k on video, photo content), but the ego can be set up in 5 minutes using a PC to display 4k all the time (in there is such a video in the internet)
stl8k
Post by stl8k » 28 Apr 2021, 10:41
It turns out that the display is 4K 120hz HDR coincidently.
Receipts
https://youtu.be/WBXAP3ZH2cA
https://www.youtube.com/watch?v=qIsr2SFNCG4&t=0s
