VG248QE user bought a XL2546K, oops..
Nm_kng
Re: VG248QE user bought a XL2546s, oops..
Post by Nm_kng » 16 May 2021, 23:12
Chief Blur Buster wrote:
16 May 2021, 15:57
Nm_kng wrote:
16 May 2021, 11:04
I've asked Zowie and they told me they don't have the same panels. I had an XL2546K for 2 weeks, I returned it because of some issues it had with the cables and Amazon didn't want to send me the cables. I wanted to ask a question, is DYAC+ on noticeable to you, because I never noticed a difference in motion clarity (in UFO tests I did), in game there was zero difference. Getting an Aorus KD25F soon :)
To see it in games well, you need
1. framerate = Hz method such as VSYNC ON, framerate cap, or RTSS Scanline Sync
2. Staring at moving objects instead of stationary objects (e.g. crosshairs)
3. Extremely high poll rate at high DPIs
Strobed results are easier to see, for example, in Rainbow Six than CS:GO. Or Rocket League. Or panning/scrolling games like DOTA/LOL. Etc.
See Re: HOWTO: Using ULMB Beautifully or Competitively
Thanks appreciate it :)
VG259QM (MAIN) | XL2546K | Aorus KD25F
SmaQ2K
Re: VG248QE user bought a XL2546K, oops..
Post by SmaQ2K » 27 May 2021, 06:11
Boomchakadah wrote:
01 May 2021, 14:02
If you don't plan on using DyAc, the XL2546K is 100% a waste of money. I would get the VG258QM or the XL2540K. My VG258QM arrived yesterday, I'm gonna start testing it tonight or tomorrow. I also have an XL2540K in transit.
How VG258QM turn out it’s it wort buying . And what about motion clarity,ghosting performance.?and do u recommend buying it for FPS games like CSGO
fluxxr
Post by fluxxr » 07 Aug 2021, 09:23
Any updates on your search prod1G and Nm_kng?
Boomchakadah wrote:
02 May 2021, 13:44
prod1G wrote:
01 May 2021, 15:33
IPS doesn't have a lower input lag than TN or vice versa. Input lag is just signal processing. It's the time difference between when there is a signal from the GPU, and when that signal is displayed on the screen. Input lag is independent of the type of LCD panel.
What factors contribute to input lag/signal processing?
AM_acc1q
Post by AM_acc1q » 08 Aug 2021, 01:06
I'm upgrading from the VG248QE to the XG2431.
I'll let you know what I think when I receive it, but it'll probably be a while before Amazon ships the monitor.
