Acer 390Hz monitor - XV252QF
Deadmanx
Post by Deadmanx » 06 Jan 2023, 07:48
So what are everyone's favorite settings for valorant or counter strike on this monitor? What gives the absolute lowest input lag and best gaming experience?
Bepli
Post by Bepli » 06 Jan 2023, 14:11
Deadmanx wrote:
06 Jan 2023, 07:48
For FPS Games Over Drive: "Extreme" and VRB: "Extreme" should be the best compromise of input lag, motion blur and overall look.
The overshoot that's coming with the Over Drive on the Extreme setting is fine for me in CSGO. Also I don't think the added input lag from VRB is anything anyone should worry about since is just ~1ms (1.8ms vs 3ms(taken from the rtings measurements)) and I was never able to tell a difference.
Some people don't like the Display being dimmer when using VRB on Extreme, but for me using a higher Gamma in the Monitor and adding some % Digital Vibrance through the Nvidia Driver makes it totally bright enough.
Also be sure to re-enable VRB regularly. If the Monitor is getting a Video-Signal where VRB is not available it wont auto re-enable it again when getting a compatible signal.
(On boot Computers usually output 60hz and thus the Monitor disables VRB and it will still be turned off when booted in the OS with 390hz).
Deadmanx
Post by Deadmanx » 07 Jan 2023, 07:07
I use normal overdrive seems to work for me... I don't think I've tried extreme.
I feel like when I turn VRB on the screen brightens up? Am I backwards with this, I believe I have VRB off..
Bepli
Post by Bepli » 07 Jan 2023, 10:31
Deadmanx wrote:
07 Jan 2023, 07:07
If you dont have Brightness Maxed, when turning VRB to Normal it will be brighter than before. But Extreme should either be similar brightness to factory default settings in brightness (I dont remember the setting) or a bit dimmer.
Deadmanx
Post by Deadmanx » 10 Jan 2023, 11:10
I'm running extreme/extreme but uncapped fps in valorant/cs get 450-700fps (more in cs than valorant)
Was the discussion previously that with TVR/VRB on that fps should match the monitor refresh rate? Thanks
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 26 Feb 2023, 12:21
Could the Flickering issue possibly be caused by the monitor overheating?
Deadmanx
Post by Deadmanx » 26 Feb 2023, 17:04
BTRY B 529th FA BN wrote:
26 Feb 2023, 12:21
i did what the acer techs told me... i did a hard reset and have NO ISSUES. i run max brightness @ 390hz and its flawless
max brightness and overdrive extreme.. all the rest off
i have changed settings since the last post i made, these seem to be the best for fps games, for me anyways.
p.s. when i first brought the monitor home i had the flickering issues... i posted on what i think the issues are when going to 390hz... When you change it on the monitor to overclock, it should automatically change your windows setting to 390hz... if it doesn't it becomes jacked up somehow and i had flickering issues.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 26 Feb 2023, 19:18
Thanks for the reply, I've done a full reset a while ago.. it occasionally flickers... noticed it was getting hot today from the sun through the window and then it started flickering and it's still winter here.
Deadmanx
Post by Deadmanx » 27 Feb 2023, 04:46
26 Feb 2023, 19:18
Maybe it could have been faulty from the start for you? Not sure but I have zero flickering, make sure you post if you get it completely fixed! Gl
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 28 Mar 2023, 11:27
Thinking of taking the back panel off and running a fan over it.. just need to keep the back cool... as the back sits facing the sun.
Anyone know how to do this?
