Acer 390Hz monitor - XV252QF
lyrill
Post by lyrill » 12 Oct 2021, 07:32
LucPls wrote:
11 Oct 2021, 13:11
Crazyness wrote:
10 Oct 2021, 23:39
how can i enter service menu? tnx
Also interested.
Anybody knows how do i check my batch date?
check in windows device manager dude.....basics for gaming gear
lyrill
Post by lyrill » 12 Oct 2021, 07:34
Anderstj wrote:
12 Oct 2021, 02:53
lizardpeter wrote:
11 Oct 2021, 18:40
Anderstj wrote:
11 Oct 2021, 14:35
I recently returned a XV252QF, cos of grainy/blurry image and i currently have a 23.8 inch, just wondering if a maybe got a bad monitor.
Coming from the AW2518H, which I believe also uses a 24.5" panel (but I could be wrong), I thought this Acer monitor looked sharper for some reason, and I don't use the sharpness feature either. I mean, there will be a decent PPI difference coming from your existing monitor for sure. Maybe the coating on the monitor is less appealing to you than your current one. Overall, I am very happy with my purchase and don't notice any kind of grainy or blurry image. I also have 1440p monitors at 27". Obviously those look a lot better due to better PPI, and I instantly noticed the massive downgrade there when I originally went from 1440p 144 Hz to 1080p 240 Hz, but I stuck with 1080p for the competitive edge that these highest end monitors give and for the extra FPS in games.
Coating was my first guess and from my research the coating should actually be the same as i have on my current monitor. Im unsure if such a small PPI would annoy me that much that i had to return the monitor, 92.5 PPI to 89 PPI seems so low. Could it be backlight bleed or IPS glow? i'm not sure, i might just try buying another one from a different retailer.
what do you guys mean by coating? you can't see/discern coatings while the monitors are lit......?
Notty_PT
Post by Notty_PT » 12 Oct 2021, 09:56
Anderstj wrote:
12 Oct 2021, 02:53
lizardpeter wrote:
11 Oct 2021, 18:40
Anderstj wrote:
11 Oct 2021, 14:35
No! PPI, just like DB (sound metric) is not linear!
What does that mean? It means that in theory you should tink 3ppi difference is nothing.
Imagine a 40db PC or Graphics card fan. It is "tolerable" (not my fav anyway). At 45db you are already hearing double noise, at 50db you are hearing a jet! So you don´t need 80db to hear double noise compared to 40db, see what I mean? Same with PPI.
PPI is one of those that doesn´t scale linear. Altho 3 ppi difference seems low, it is more than enough for a good eyesight to spot differences. This is why a lot of ppl complain about 1080p crispness on 24,5 inches. However you have a lot of guys using 27 inch 1080p and they can´t notice anything wrong with pixel density right?
We are all different
If you find 1080p 24,5 to be blurry, trust me, you won´t like any 24,5 screen ever. Stay away. I have the same problem btw. I mentioned a lot of 23,8 panels advantages and that´s another one. Plus remember, the smaller the pixel pitch, the better perceived pixel response time. You can try this on your current monitor. For example, run a game at 1600x900 or 1366x768 on your screen, with the exact same framerate you get at 1080p. Do fast movements. See how awful it seems? Because now you have to deal with massive pixels transitioning.
Another reason why I despise most of those AUO 24,5 panels (they seem to always manufacter that size, while BOE and Innolux use smaller ones). We have a great explanation here by Chief! -> viewtopic.php?f=2&t=8113&start=480#p72862
23,8 inch 1080p or 27 inch 1440p to me. No other option. Would GLADLY take a 24 inch or 24,5 inches 1440p. But can only get a Dell S2417DG 23,8 1440p 1ms TN, BUT.... 165hz only. Not bad, but only if it was 240hz....
lyrill
Post by lyrill » 12 Oct 2021, 10:21
dude...we've all used iphone 4 since 2010, you aren't the only one who's been graced with retina screen master race. there is no difference from a 4 inch display to a 24 inch display of the same ppi, in terms of/as far as/concerning how superior the ppi is, they feel the same, now you will say font size and use distance, that's your choice, but the physical capability of the electronics stay the same.
In fact isn't iphone 4 ppi way higher than your 23 inch 1080p?
ofc it would be nice that every pcmr high hz monitors are same ppi as iphone 4 and suddenly there is also not an up in demand on the gpu and you can run the same fps, matching hz as you were, but that's not the world we live in.
On the other hand, screen size does matter, and you have said it many times, there is a drawback of bigger pixel on screen, but isn't that also a perk in the first place? It means you can throw the screen further away. it means your arms and gear can rest on the desk more.
these are good talking points, the industry is indeed very lacking in many regards, nobody is talking about what's the best monitor size, what should be the pick of choice. it seems like people are just being told what's arbitrarily "available to buy" so it's extremely none consumer friendly, or should I say, normal consumer, as in otherwise power consumer if you assume "normal" consumer means dumb wallets.. But that's also exactly why, we need more than just 1 or 2 power consumer providing opinions. we need as many power user as there can be and we need to unite to fight back on dumb consumerism dumbing things down and delaying real progress for all.
Salemthecaz
Post by Salemthecaz » 12 Oct 2021, 11:53
Hey guys! I NEED SOME BIG HELPS HERE!!!
My XV25 just got delivered this morning, and it’s from the JANUARY BATCH, which is the batch with the most problems(the march batch seems to be better).
Any major issues I need to be aware of? And should I return it if there’re too many problems? Wait for newer batch to come out?
Thanks a lot in advance, any help is much appreciated!!!
Salemthecaz
Post by Salemthecaz » 12 Oct 2021, 14:23
Alright so I couldn’t wait no more for any helps so I did some research myself!
FOR ANYONE WHO BOUGHT THE JANUARY BATCH OF THIS MONITOR XV252QF( can be found on the box 📦)
On Acer website, I found a driver update for this monitor on March 2nd, which if you update this on your January batch monitor, supposedly it’ll be updated and fixed most of the bugs to be equally even with the March batch!
Here’s the link: https://www.acer.com/ac/en/US/content/s ... t/8842?b=1
And I also found the Acer display widget application which supports this specific model, also in the link I stated above!
Hopefully you guys will be able to update it and fix most of the bugs, instead of having to return it. I assume the March batch is pretty identical with the January one with just the driver update!!!
reffp
Post by reffp » 12 Oct 2021, 14:38
Anderstj
Post by Anderstj » 12 Oct 2021, 16:29
lyrill wrote:
12 Oct 2021, 07:31
Anderstj wrote:
11 Oct 2021, 14:35
CJRS wrote:
11 Oct 2021, 04:46
This weekend I have tried the AOC 24G2Z that Notty claims to be better than all 360 hz+ screens (its only 300 euro, so not that expensive). But this is absolutely not my experience, I could tell it's more responsive and no ghosting issues compared to older models in 240hz category but no where near as snappy than on this acer. I also have the AW2721D 240hz 1440p and this xv252QF is just that good that I can't even go back to 240hz anymore. Aiming and responsiveness is for me is really a huge difference. Even compared to the new generation 240hz panels/tech. The biggest difference u will notice is microaiming on 8k polling rate and corner shots plus input lag.
Mine is manufactured in march 2021.
When it comes to clarity and colors the AW2721D absolutely shits on the xv252qf, but when it comes to performance, its the total opposite, and that's the most important for me.
The only monitors that would be considered to be an upgrade is either 1440p 360hz+ or 1080p 480hz when it gets released.
Did you notice a difference in PPI? from 23.8 to 24.5 inch / difference in sharpness? most noticeable in windows / when browsing. I recently returned a XV252QF, cos of grainy/blurry image and i currently have a 23.8 inch, just wondering if a maybe got a bad monitor.
there is a super sharpness, did you try it?
Yea, sharpness didn't help at all, but like i said earlier, it wasn't very noticeable in games, mostly text in windows and browsing stuff on the internet, and strangely id say it was the worse or most noticeable on the left side of the monitor.
Anderstj
Post by Anderstj » 12 Oct 2021, 16:33
Notty_PT wrote:
12 Oct 2021, 09:56
Anderstj wrote:
12 Oct 2021, 02:53
lizardpeter wrote:
11 Oct 2021, 18:40
Anderstj wrote:
11 Oct 2021, 14:35
Thanks for the long reply, i learned alot. I kinda wish a 24 inch 1440p 240hz or 23.8 inch 390hz was an option right now, that would be awesome. Might just wait and see what happens in the future, do we know if stuff like that is coming anytime soon in the future?.
lyrill
Post by lyrill » 12 Oct 2021, 16:54
Salemthecaz wrote:
12 Oct 2021, 14:23
Jan batch were shipped as early as Feb 6th or something. This driver you talk of looks to be Feb 3rd. It probably is already updated to that, since there is no listing of other versions, and it's literally called 1.0.
the widget is even older, what does it even do?
