Has anyone managed to get 1440p 120hz 10bit or 12bit to work over hdmi 2.1?
I know there’s enough bandwidth for the signal to pass but I think it’s an HDMI EDID issue.
If you got it to work make sure you have 10bit information displayed on the receiving end which is TV because you can send this signal over windows and Xbox but the display downscales color depth to 8bit.
Edit: for LG OLED Users check this link to show how you get the detailed resolution. http://ltroyalshrimp.com/how-to-get-int ... tics-menu/
To clarify: I can make this resolution to work on both windows and Xbox. 1440p 120hz 10bit 12bit works, but it downscales at the display end and always shows 8bit. So if you have this working you might be using 8bit this whole time thinking you were on higher bit depth.
1440p 120hz (10bit) not possible over HDMI 2.1?
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
