Samsung LC27RG50 problem
sharas
Post by sharas » 12 May 2021, 12:08
Hello i have samsung lc27rg50 240hz gsync compatible monitor my pc has geforce gtx 1660 graphics card
when i enable gsync in nvidia control panel and check the enable settings for the selected display box when i play games when in any motion there is terrible light coming from all edges its white and looks like all colors in one when i stay still it looks fine but when i move or move camera white lines come from all edges. I found that unchecking enable settings for the selected display fixes this problem but then it doesnt feel as fluid as with that option turned on. Is there a fix , because i tried every setting in the monitor itself and in nvidia control panel and nothing helps.Should i just buy a new monitor ? im thinking about asus tuf 144hz but will there be the same problem ?
