Hello,
i have an issue an i need your help,
i recently bought a 360HZ monitor " Alienware AW2521h " and i want to use it as external monitor for my laptop " MSI GP76 Leopard 10UG-648XFR "
the problem is i do only have 2 ports for display on my laptop 1 is HDMI and the other one is Type-C USB3.2 gen 2 w/ DP1.4
so i connected it with DP cable IN into my monitor and mini DP out with an Apple adapter mini DP to USB-c / thunderbolt 3
and the problem is it seems like it does not support 360HZ refresh rate, when u switch to 240hz 144hz it works perfectly but when i try to set in to 360HZ the monitor is turning OFF like for 1 - 2 sec then ON it happens randomly, ive already checked everything related to software like drivers or any other that my create a conflict, someone have an idea where to look? what is the problem?
maybe the adapter mini DP to USB-c does not support 360HZ ...
any suggestion?
360HZ display port to USB-c
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
