BenQ Zowie XL2540k vs Asus VG258QM
So Ive been on a monitor binge lately and prefer TN panels. Ive ordered the 2 monitors listed in the title and both had noticeable inverse artifacts. Is this a norm? I also ordered the Viewsonic XG2530 but it didnt feel near as responsive imo.
Re: BenQ Zowie XL2540k vs Asus VG258QM
Pixel inversion artifacts can affect any monitor. if you have the option and patience, try another unit. Neither my XL2540K nor my VG258QM had pixel inversion issues.
You wasted your time on that XG2530. it has a very high input lag compared to other 240hz monitors.
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
@Boomchakadah how do you like the 258qm? I'm currently deciding between the 8qm and the 9qm
Why is the XG2530 listed in the monitor list then? Thought only the best ones was listed... https://blurbusters.com/faq/120hz-monitors/Boomchakadah wrote: ↑27 May 2021, 10:31
Pixel inversion artifacts can affect any monitor. if you have the option and patience, try another unit. Neither my XL2540K nor my VG258QM had pixel inversion issues.You wasted your time on that XG2530. it has a very high input lag compared to other 240hz monitors.
