Hello everyone
There is a thing that bother me and I don't understand it neither.
I'm using a Z35p for a couple of years now, great monitor, G-sync work fine with the recommandation of Blur Buster.
I understand how G-sync and V-sync work. I consider myself having a good knowledge on display and how everything about it work.
But why, with G-sync enable, everytime I hit below 60fps I got stutter. No tearing at all, but below 60fps it work like i'm using software V-sync, got stutter and fall to 30fps.
It's easy to fix that by having allways more than 60fps but some games (hello Cyberpunk) are a pain in the ass and get down around 50/55fps.
So now i'm pissed about it.
Am I not supposed to have a stutter free experience with G-sync enable? What cause this stutter, and why at 59fps and not at 119fps?
Thank you
What is causing stutter with a VRR screen below 60fps
Re: What is causing stutter with a VRR screen below 60fps
Is it happening in all games? Stutter like this usually implies that the game is CPU-bound rather than GPU-bound. Unless you're playing in windowed mode with g-sync. Then stutter also occurs when GPU-bound.
Yes, everytime a game is too badly coded and even with my setup it drop below 60fps it's happening.
I'm playing in full screen but I used to play in windowed fullscreen and it was the same.
Is this regular stutter like the low-framerate UFOs at bottom of www.testufo.com#count=4 ? Unfixable.
Or is this erratic stutter like www.testufo.com/stutter ? Sometimes fixable.
If erratic stutter, how big is your VRR range?
If your monitor is only 144Hz, there can be visible LFC erratic-stutter too.
LFC erratic-stutter is more invisible on monitors with wide VRR ranges, e.g. 48Hz-240Hz VRR.
You can improve low-framerate "regular stutter" somewhat by enabling GPU motion blur again in the Cyberpunk menus. This will make motion even more blurry but it will mask some of the stutter. Anything ~60fps and up, I recommend disabling GPU motion blur effects.
In fact, it's not really stuttering
It'smore it feel like, everthing is smooth at 60fps and above and immediatly at 59fps it feel laggy.
I mean, you don't notice a difference between 62 and 65fps, but here I clearly notice everytime I hit 59fps
Hello guys
I was thinking about that again while playing Cyberpunk, despite having a 7800x3D now I still got some moments where the GPU is not 100% usage... so sometime it got under 60fps.
So after those almost 3 years, it's still the same. Whenever I go under 60fps it become, it become laggy. I'm now running a AW3423DWF of course nothing change.
61 fps is totally fine (even i'm now use to more, like 70to90 usually) but 59fps is immedialty terrible. I shouldn't notice difference between 61 and 59fps, but there is a difference, a very noticable one
Is there something to do with 60hz behing the standard, or frametime or idk whatelse? Still a mystery
In my experience, there is a subtle, but notable drop in perceived fluidity from 60+ FPS to 59 FPS (and below) at 60Hz, regardless of the game (or configuration, be it monitor, system components, etc), with or without CPU/GPU limitation or G-SYNC.
It's just how sub-60Hz feels (and has always felt, especially when synced), and since 59 FPS = 59Hz with G-SYNC, this feeling will remain.
G-SYNC does not make a lower frame/refresh rate feel higher, it merely prevents tearing artifacts for framerates within the refresh rate.
Even with Nvidia Reflex?
So you feel exactly the same as me. And you have no explanation for this behavior.jorimt wrote: ↑23 Mar 2024, 19:42In my experience, there is a subtle, but notable drop in perceived fluidity from 60+ FPS to 59 FPS (and below) at 60Hz, regardless of the game (or configuration, be it monitor, system components, etc), with or without CPU/GPU limitation or G-SYNC.
And apparently since you know your subject, I guess no one will put a word on what is happening under 60fps
thank for you help
I have an explanation, it's just not a satisfying one; 59 FPS/Hz isn't 60 FPS/Hz.
There are thresholds where perceived fluidity changes based on the frame/refresh rate, and some players are more sensitive to this than others, some not at all.
For instance, say you're playing a game with G-SYNC on a 240Hz monitor, and it fluctuates anywhere between 30 and 240 FPS at 240Hz. I can easily tell without any visible readouts the general framerate range I'm in, typically at 15, 25, 30, 45, 50-59, 60, 75, 85-100, 120+ FPS (with anything well above 120 FPS/Hz becoming less and less visually impactful, at least compared to 30 vs 60, or 60 vs 120), and I'm usually within a few frames of what I'm feeling when I do enable the readouts.
What causes this is the direct contrast between the varying frame/refresh rate in real-time.
It's much less noticeable if you play at a fixed framerate instead of letting the average framerate vary wildly. I.E. a 30 FPS console game is tolerable only if it's a consistent 30, but once you switch to 60, it's immediately intolerable and you can't imagine how you were playing at that framerate the entire time, and so on.
It's similar to the difference between trying to pick out subtle differences between two otherwise identical side-by-side image, or alternating between the two at will (one over the other); the latter makes any differences, no matter how small, obvious, whereas the former does not.
