The thing is this only happens on the Edge browser combined with this Predator monitor. If I use my laptop monitor there is no issue at all. Another weird happening is when I'm watching Youtube video on Edge with this monitor, some of the colors turn grey or "off". I am not seeing this issue with Chrome browser. I am not too knowledgeable about monitors and would like some opinion why this is happening.
In the first image the purple line starts with "the".
In the second image the purple line starts with "would".
My monitor is Predator 273U GX 1440p 240Hz and I am having this issue with purple line in the Edge browser.
- 20210618_172256.jpg (5.77 MiB) Viewed 856 times
- 20210618_172027.jpg (5.97 MiB) Viewed 856 times
Re: My monitor is Predator 273U GX 1440p 240Hz and I am having this issue with purple line in the Edge browser.
This is usually a ClearType tuning issue combined with Sharpness.
1. First, go into your monitor menus, and adjust Sharpness down to a neutral setting.
2. Next, search "adjust cleartype" in the Windows Search Box next to your Start button at bottom-right.
3. Run the app that shows up.
It's the ClearType Tuning wizard, which will adjust/fix some color fringing of your text.
Once you're done with that, adjust Edge options by copying and pasting this URL into your Edge browser:
Try both settings.
Now, if the purple fog between letters still remain, there may be other problem. But it's often an interaction with two mis-adjusted settings (Windows ClearType + Monitor OSD Sharpness) that sometimes generate color fog between letters. The sharpness adjustment in monitor menus can blends the color-fringing of ClearType to the whitespace between adjacent letters, creating a color-tinted fog that appears.
Occasionally and very rarely, this can also be caused by misadjusted LCD inversion (fine chessboard texture artifacts appearing in solid colors), that is interacting with text. Check Lagom Inversion to see if there's really dramatic purple/green colors or super-nasty flicker suddenly flashing in those grey patterns. A minor amount is normal for most panels. Imbalances in the normal voltage inversion algorithm would have to be unusually strong for it to begin artifacting ordinary text in this fashion. Try the other fixes first.
Code: Select all
edge://flags#edge-enhance-text-contrast
