New pc stutters in every single game. Random frame time skips despite good fps
stuttersolver
Re: New pc stutters in every single game. Random frame time skips despite good fps
Post by stuttersolver » 06 Jul 2021, 13:06
No everything is turned off, brand new windows 10 format. thanks for your help. Yes my sekiro has random frametime spikes from 16ms up to 30,40ms + as you can see in that vid.
At this point ive basically done everything, I have been reading that it can be a problem with the wiring in my house or 'dirty electricity' causing bad power to my pc or something? I Have no idea.
Post by RealNC » 06 Jul 2021, 13:34
stuttersolver wrote:
06 Jul 2021, 13:06
I don't think that would be that selective. Like it only occurs when you move around in the game. Also, the electricity in my house is kinda atrocious. If I don't buy Philips LED bulbs that have their own AC to DC converter, they will pulse very often because of unstable voltage. So I have pretty much the worse electricity quality imaginable basically, but zero problems in games.
Maybe it's RAM? I don't know. I use 16GB (2x8 dual channel) 3600MHz RAM (XMP.) Maybe that affects it.
Actually, let me run a test. I'll disable XMP so the RAM runs slow (I think it's 2333MHz without XMP.) I'll report back.
Post by RealNC » 06 Jul 2021, 13:48
OK, I tried Sekiro again with XMP disabled. This dropped the RAM speed from 3600 to 2133. No stutters. So that's probably not it.
stuttersolver
Post by stuttersolver » 06 Jul 2021, 14:05
Your graph is just entirely solid the whole time? mine is definitely not and has constant spikes. I really wanna solve this.. guess ill go format windows just in case
Post by RealNC » 06 Jul 2021, 15:04
06 Jul 2021, 14:05
Well, minor frame time spikes (like 2-3ms) are not a cause for concern. Larger ones are what result in stutters. I did a recording of Sekiro with RTSS enabled. I do get a few minor 2ms or so spikes, but they don't produce stutter:
https://www.youtube.com/watch?v=8V2J_RdiG6c
stuttersolver
Post by stuttersolver » 06 Jul 2021, 17:11
yeah thats way better than mine. Mine spike by ~20ms... not sure what to do next
stuttersolver
Post by stuttersolver » 07 Jul 2021, 13:55
really bad frametimes plz help
stuttersolver
Post by stuttersolver » 07 Jul 2021, 17:47
Yeah I tried xmp on and off doesnt make a difference. The ram is 8x8gb kit TEAMGROUP DDR43200 CL16-18-18-38 1.35v here is the ram : https://www.newegg.ca/team-16gb-288-pin ... 6820331354 Here is my cpu-z https://i.imgur.com/yVyRbQZ.png
stuttersolver
Post by stuttersolver » 07 Jul 2021, 18:17
CapFrameX results from 60seconds of capturing sekiro
