Hi,
I read the following here : The 2540K is using the AUO M250HTN018 that is a refresh of the panel used on the OG 2540 (AUO M250HTN010).
However, I found this on reddit
Which therefore implies they have the same one. Can anyone confirm which is true and if the K version is actually an upgrade over the OG.
Thanks
Zowie XL2540K Panel?
Re: Zowie XL2540K Panel?
What you read here is correct.pstn wrote: ↑22 Jul 2021, 01:09Hi,
Thanks
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
