I'm in the market for a new monitor. My current monitor is a 5 year old 1440p 144hz G-Sync monitor.
I have heard that native G-Sync monitors feel smoother compared to G-Sync Compatible displays. Is there any truth to this? If budget isn't an issue, is it still worth looking into native G-Sync displays?
How about also in terms of the range of supported refresh rates? I also understand that G-Sync compatible displays have more limited ranges of VRR whereas native G-Sync tends to support ranges from 1Hz to 240hz (or whatever the max rated refresh rate of the display is).
Anyway, just looking for some general advice as I go into shopping mode.
In terms of what I'm looking for, my ideal monitor would be the following:
27", 1440p, 240hz, native G-Sync (G-Sync Ultimate ideally), with good HDR performance (600+).
However, since native G-Sync displays seem to be few and far between nowadays, I'm wondering if I should just give up on that and go with a G-Sync compatible display instead.
G-Sync vs G-Sync Compatible (Relative Smoothness)
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
