yes chief..you are right as always..but you still didnt answer my question
coming from the 2k 144,should 2431 with BB stamp on it be the answer?
if we use the common BB formula 60-120-240-480 or 144-360-390...
whats the best option right now 2 safely transit next year or 2?
so if its up 2 you,and you wanna 2 use d monitor for variety of games including option 2 play with and without back-strobe
what will you opt 4?
this is d only choice: 240 BB stamp on it vs 390
+ we need 2 consider impact from d next monitor we buy,
so lets say i opted 4 390..should i be amazed with that 480hz?
or it will be like yeah..quite allright not blown away type of experience
again using BB formula ^
or its buy now and be steady 4 a next decade..
and if i opt 4 240 BB which i will most certainly do,
first off..bcs you did d tuning
we are on yours forum
we are gaining knowledge from this place
yours perception is branded into d way panel will fight with d blur
and i saw ufos from that BB seal of approval..
aka BB>dyac+
and if we ask the same question about next monitor we buy ..
using d same BB formula
should i be amazed with that new panel or is it d same answer again..
buy now and be peaceful 4 d next at least 5years?
