new monitor
basterman
new monitor
Post by basterman » 23 Aug 2021, 12:01
I need help with a nice monitor. I have around 1000 Pounds. Likewise, I want to buy huge one if it is possible for my PC for gaming. I can add another 300 pounds - I hope. Can you hwelp me ?
Discorz
VIP Member
Re: new monitor
Post by Discorz » 23 Aug 2021, 16:33
What is your gpu and cpu? What games do you play?
Which resolution and size did you have on mind? Do you use motion blur reduction?
basterman
Re: new monitor
Post by basterman » 29 Aug 2021, 14:04
I have Ryzen 3600 and 1660 Super . Mow I'm playing Fortine, CALL of Duty warfare, GTA 5 again . I don't use motion blur reduction ( I don't really know whats this )
lizardpeter
Re: new monitor
Post by lizardpeter » 29 Aug 2021, 21:51
basterman wrote:
29 Aug 2021, 14:04
With a 1660 Super, you really won’t be able to take advantage of most of the top monitors. What resolution and frame rate are you targeting?
i9 9900k | RTX 2080 Ti | 32 GB 4x8GB B-Die 3600 MT/s CL16 | XV252QF 390 Hz 1080p | AW2518H 240 Hz 1080p | PG279Q 144 Hz 1440p
Razer Viper 8K | Artisan Zero Mid XL | Apex Pro TKL | 1 gbps FiOS (Fiber)
basterman
Re: new monitor
Post by basterman » 14 Sep 2021, 01:25
I have no idea. I don't know too much of monitors. I don'r understand all options either.
Discorz
VIP Member
Re: new monitor
Post by Discorz » 15 Sep 2021, 02:35
I'd recommend you go for 1080p 144Hz fast IPS with 1660s. But if you plan to upgrade your gpu or cpu in future you can go higher-end.
By saying big do u mean like 32 or 27"? 1080p 32" IPS are non existent. That combo is VA panel only which I wouldn't recommend if u care about response times and pixel density.
27" can be easily found. Good options should be LG 27GN650, LG 27GN600, MSI G271, BENQ EX2710 if it could be found at a reasonable price.
basterman
Re: new monitor
Post by basterman » 22 Sep 2021, 02:17
Thank you , I will check it. I'm thinking about upgrading my pc in the future, but not know. I have to many thing to buy it before new pc. I prefer at least 32"
Discorz
VIP Member
Re: new monitor
Post by Discorz » 22 Sep 2021, 02:54
basterman wrote:
22 Sep 2021, 02:17
AOC C32G2ZE (32" 1080p VA 240HZ) is the one I used to want for big screen gaming. It is very cheap in my region. But be aware of very slow response times, smearing and other VA panel flaws.
