Hello, I have Xl2546, i use manual with 182hz strobe trick, its so beutifull. But i have one trouble, i have smooth picture only when my fps 165 and lower, when fps 165+ 200 220 240 i have no smooth picture(twitching, shaking) with diac
Maybee can trouble on my cpu? 6700 non k, but game no freeze and in game fps 140+
Xl2546 dyac and stutters
Xl 2546
Re: Xl2546 dyac and stutters
I play apex legends and i see in monitor settings with dyac game open with 144 hz, but i have 182 on nvcp, and i dont know how switch
Xl 2546
Don't use the NVCP. Use ToastyX CRU. NVCP creates GPU scaled resolutions, which aren't always what the monitor is _receiving_. We saw this years ago before the Benq 220hz overclock thread turned into a megathread. People were doing 180hz overclocks with the NVCP on XL2411Z's but it was actually 144hz to the monitor and 180hz through the driver, which created desync problems. So always create them in ToastyX CRU then reboot.
Its work, u are the Best <3Falkentyne wrote: ↑16 Sep 2021, 12:51Don't use the NVCP. Use ToastyX CRU. NVCP creates GPU scaled resolutions, which aren't always what the monitor is _receiving_. We saw this years ago before the Benq 220hz overclock thread turned into a megathread. People were doing 180hz overclocks with the NVCP on XL2411Z's but it was actually 144hz to the monitor and 180hz through the driver, which created desync problems. So always create them in ToastyX CRU then reboot.
Xl 2546
Thank you, my friend, everything worked, the picture with diak looks better than with g sync
Xl 2546
how can i prevent that?Falkentyne wrote: ↑16 Sep 2021, 12:51Don't use the NVCP. Use ToastyX CRU. NVCP creates GPU scaled resolutions, which aren't always what the monitor is _receiving_. We saw this years ago before the Benq 220hz overclock thread turned into a megathread. People were doing 180hz overclocks with the NVCP on XL2411Z's but it was actually 144hz to the monitor and 180hz through the driver, which created desync problems. So always create them in ToastyX CRU then reboot.
and is there any sort of test that i can run?
so how can i check what is actually done thru monitor and what is done via driver?
is this universal thingy or is it just related 2 only dyac monitors?
am asking this bcs i dont own an dyac..but i sometimes experiment with large VT
and i was never certain if i am actualy using large VT res..bcs no backlight strobe..
and i am not quite certain what 2 delete in cru,shoud i delete those 2 defaults res ?
or should i delete that cea blocks or whats d proper way 2 do it?
