Is there a software analogue for ulmb?
Posted: 19 Sep 2021, 11:52
Is there a program that allows you to enable backlight strobe on any monitor?
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
Lightboost, which allows you to enable strobing on some monitors that have nvidia 3D vision support. See:valeriy l14 wrote: ↑19 Sep 2021, 11:52Is there a program that allows you to enable backlight strobe on any monitor?
Also, software-based black frame insertion can help but requires you to use a lower refresh rate, and control persistence in increments of max-Hz refreshtimes. Example www.testufo.com/blackframes .... Some emulators like RetroArch has this optional feature.valeriy l14 wrote: ↑19 Sep 2021, 11:52Is there a program that allows you to enable backlight strobe on any monitor?
