Is there a software analogue for ulmb?
valeriy l14
Post by valeriy l14 » 19 Sep 2021, 11:52
Is there a program that allows you to enable backlight strobe on any monitor?
Re: Is there a software analogue for ulmb?
Post by RealNC » 21 Sep 2021, 13:33
valeriy l14 wrote:
19 Sep 2021, 11:52
Lightboost, which allows you to enable strobing on some monitors that have nvidia 3D vision support. See:
https://blurbusters.com/zero-motion-blur/lightboost/
This only works with very few (and quite old by now) monitors. Nowadays, if the monitor can strobe, it offers that function natively. If not, there's nothing you can do to force strobing.
Post by Chief Blur Buster » 21 Sep 2021, 14:02
valeriy l14 wrote:
19 Sep 2021, 11:52
Also, software-based black frame insertion can help but requires you to use a lower refresh rate, and control persistence in increments of max-Hz refreshtimes. Example www.testufo.com/blackframes .... Some emulators like RetroArch has this optional feature.
Only hardware-based backlight strobing allows sub-refresh control of display persistence.
But very few allows software control of backlight settings, as they require a form of API between computer and monitor, and not all monitors have such APIs.
They include the following:
LightBoost - www.blurbusters.com/lightboost/howto/
Benq DyAc - www.blurbusters.com/strobe-utility
XG2431 PureXP - www.blurbusters.com/strobe-utility-viewsonic
Eve Spectrum - www.blurbusters.com/strobe-utility-eve
