Backlightbleed or IPS Glow
JustPeterinanutshell
Post by JustPeterinanutshell » 27 Sep 2021, 09:41
Hey guys i bought a vg259qm and im curious if this is backlight bleed or ips glow?
And when it is ips glow is this nromal one or should i return it?
https://imgur.com/a/SJcRGSF
Re: Backlightbleed or IPS Glow
Post by jorimt » 27 Sep 2021, 10:28
JustPeterinanutshell wrote:
27 Sep 2021, 09:41
That looks like IPS glow to me. To confirm, take another photo a few feet away from the monitor; if that pattern mostly or completely disappears (but for any backlight bleed), it's glow.
As to if it's "normal," depends on the model. That said, unlike backlight bleed, there's isn't usually a lot of variance in IPS glow from panel to panel of the same model, so that level of glow is probably normal for that model.
Post by RealNC » 27 Sep 2021, 13:37
IPS glow disappears if you look at the display from different angles. BLB does not.
