hey guys, i´ve been using a omen x25f for the past year..
and its okay i guess, the issue i have with this monitor is the sharpness setting..
it has 7 sharpness levels, where 1 thru 6 dont really do much and are still blurry, and the 7th setting called "sharp" is way too much..
like it goes 1-6 nothing and then 6 to 7 an insane amount, there is no inbetween
also when i i flick my mouse around and any kind of fast movement, its so blurry, when i move slow its quite clear
has someone had both of these monitors? and can you tell me if the benq is better? overall
from x25f to XL2540K ??
Re: from x25f to XL2540K ??
What response time mode do you use? I am using this monitor for a year and I can't say I experience blur at the same extent as you
what about VG259QM
would that be a better monitor than the x25f?
someone recommend me something, mainly for cs
Try Brightness 20, Contrast 65, Dynamic Contrast off, Gamma 2.2, Sharpness Level 5, Color Gamingwhiteboyswag wrote: ↑11 Oct 2021, 05:23i use:
response time: level 3
gamma: 1.8
sharpness: level 6
color mode: hp enhance+ "low"
