XG 270 / M32Q / MSI Optix MAG274QRF-QD / LG 27GP850-B
GregAlaSemoule
Post by GregAlaSemoule » 14 Oct 2021, 04:21
Hello.
I am looking for a screen with as little blur as possible like everyone else on the forum after spending months reading the various tests and opinions on the forum, i can't choose : I hesitate with these 4 screens. I would like to use ULMB to keep the screen clean.
My configuration is 3700X + 3060 TI. The screen will only be used to play. largely to first person shooters like Apex legend. 80% FPS 20% solo Game.
The XG270 from what I read it is necessary to use 119Hz and activate the pure XP it is not VRR + ulmb.
APex legend will easily run at 119 FPS by limiting FPS to 119 in the Nvidia control panel. but you have to activate the Vsync :( so as not to have an artifact?
But the games like Assasin Creed Odyssey and that the games oscillate between 80 and 110FPs it will necessarily be necessary to lower the frequency of the screen to 80 hz? or will it work well in ULMB at 80 fps if the screen is set to 120 hz? I don't know if you will understand me, I think the Blur Buster certfication for the XG270 means that there will be no artefacts and the games will be sharp between 75 and 119 FPs.
It's 1080P in 27 inch too bad but if it's sharp and precise it will require less GPU power and V sync On? . 82PPI.
The too large M32Q 1440P, requires more GPU power. But it has the particularity of having the VRR activatable with ULMB between 85HZ and 170 Hz which looks magnificent for blur effects and tearing if it works well together. 93PPI a little better than the XG270 pixel density
It will run solo games like The witcher 3 which will be able to keep up to 85 fps easily with the 3060 ti by lowering some graphics options. but not the Latest AAA.
https://www.rtings.com/monitor/tools/co ... shold=0.10
The MSI Optix MAG274QRF-QD, Good size, good pixel density.
no VRR with ULMB. ULMB 120 to 165Hz. So it will be limited to 120 HZ the screen otherwise risk of artifact if the games oscillate between 120 and 165 FPs for fast games? as well as disable ULMB for games like AC Creed which runs between 60 and 90 in 1440P? 109PPI.
the LG 27GP850 looks like the MSI but cheaper. ULMB looks worse than this one.
Hard Hard to choose. not a lot of choice. the XG2431 is not available in europe.
Thanks you for read me. I continue to read other Topic for found more information.
