XG2431 or VG259QM
Photonic
XG2431 or VG259QM
Post by Photonic » 17 Oct 2021, 21:53
Hi all,
I have been trying to find a new 24" 1080p monitor to use for Gaming and other digital work. I really want low latency, low blur., and will likely use GYSNC/VRR. Not sure if I will use strobing; likely I will switch between using it and not. I have narrowed it down to these two choices. Viewsonic XG2431 or Asus VG259QM
They are basically the same price in the US, the only thing is that the XG2431 is still on pre/backorder everywhere.
Anyone have opinions on if I would notice a huge difference, and if it is worth it to wait (likely months) for the XG2431?
