VG259QM best overdrive to play PUBG
GOR1L4
Post by GOR1L4 » 23 Oct 2021, 14:40
I wanted to know what is the best overdrive to play PUBG which varies a lot FPS in certain areas, the beginning of the match looks wonderful with 250FPS but in the end with a lot of players around it drops to 100/130FPS and I feel a horrible lag with the blurred image no longer has that fluidity it looks like 60hz.
I currently use-
Overdrive 120 secret
No synchronization
Level 3 shadows
zalb
Re: VG259QM best overdrive to play PUBG
Post by zalb » 17 Jul 2022, 11:04
Hi, did u find any good settings for the monitor in pubg? I also experience what ur describing and i have never felt really supersatisfied with the monitor cause of that, but i suspect its the game itself that is just shitty optimized and when fps goes down and the frametimes are low.
im using 280hz, 120od, shadow 3 and no syncs.
vg259qm owner
Post by vg259qm owner » 20 Jul 2022, 18:05
80 OD if not it's relative to the FPS right?
