That’s fair to say clarity is also more important in Fortnite. However, it’s also a lot easier to get 400 FPS+, magnifying the benefits of a 390 Hz monitor in terms of responsiveness and fluidity. In game when I compared both the 390 Hz and 240 Hz TN side by side, I could not see a difference in motion blur. So I really don’t think it’s miles behind or anything like that. I mean looking at the objective figures you’re actually talking faster response times over TN in some categories and maybe 1 ms worse in others. Anyway, the Acer with backlight strobing could have the best of everything in Fortnite.IIISLIDEIII wrote: ↑18 Nov 2021, 07:34As for fortnite I think it is much more demanding in terms of image clarity than cod, I think that on fortnite a tn is required to perform well.
Comparison benq xl2546k, hp omen x25, acer nitro xv252qf,msi mag251rx
Re: Comparison benq xl2546k, hp omen x25, acer nitro xv252qf,msi mag251rx
i9 9900k | RTX 2080 Ti | 32 GB 4x8GB B-Die 3600 MT/s CL16 | XV252QF 390 Hz 1080p | AW2518H 240 Hz 1080p | PG279Q 144 Hz 1440p
Razer Viper 8K | Artisan Zero Mid XL | Apex Pro TKL | 1 gbps FiOS (Fiber)
According to this review, 2k IPS's panels are faster with default overdrive than current 1080 IPS's, percentage transition within refresh window 77-90% and I don't see any overshoot with xv272ux normal overdrive: https://tftcentral.co.uk/reviews/dell_alienware_aw2721dIIISLIDEIII wrote: ↑17 Nov 2021, 23:10
thanks for your thoughts.
There is very good talk of 2k 270 as asus and acer, I'm curious to try one of these but it's the size that holds me back, I have a lg 27gn850 (2k 144hz) and it's really hard for me to be fast with my eyes on 27 inch.
But I don't understand how it is possible that these 2k have less motion blur than ips 1080, really strange.
Also 2k gives additional sharpness to image, so at the output a near perfect image(as for me after the tons of 240hz 1080 panels)
I had been using vg279qm before for one year and it was slower and no so sharp(of course as it has 27 with 1080), but had perfect input lag.
I think that having image clarity is "almost" always the most important thing among the various needs, especially in Fortnite.lizardpeter wrote: ↑18 Nov 2021, 14:53That’s fair to say clarity is also more important in Fortnite. However, it’s also a lot easier to get 400 FPS+, magnifying the benefits of a 390 Hz monitor in terms of responsiveness and fluidity. In game when I compared both the 390 Hz and 240 Hz TN side by side, I could not see a difference in motion blur. So I really don’t think it’s miles behind or anything like that. I mean looking at the objective figures you’re actually talking faster response times over TN in some categories and maybe 1 ms worse in others. Anyway, the Acer with backlight strobing could have the best of everything in Fortnite.IIISLIDEIII wrote: ↑18 Nov 2021, 07:34As for fortnite I think it is much more demanding in terms of image clarity than cod, I think that on fortnite a tn is required to perform well.
Cod isn't as fussy as fortnite but having clarity isn't bad there either.
If you can play with 220 nits, the acer, with Mbr on extreme and 390hz, is the best there is for fortnite, unfortunately I can't play with 220 nits even if I close all the windows and stay in a room dark, after a while my eyes get tired.
I can only tell you what my eyes are seeing these days having the acer in comparison with Omen, who is considered one of the tn with the best response time on the market (only monitor on rtings to have taken 10 on response times).
If you keep Acer without Mbr the difference is great, the omen is clearly clearer, there is a very important difference in game, then there can be people more or less sensitive to blur but frankly if I made my mom look at the monitors (who doesn't he understands nothing) she would notice it too.
By activating Mbr to the maximum on Acer the difference is greatly reduced, I would say that at that point they are comparable but back to the starting point, I can't play with 220 nits, especially on cod.
However I am not saying that acer should be abandoned, if you are willing to accept a bit of blur (for those like me who use it without mbr), it has several advantages over Omen, it is more snappy, responsive and has very little tearing, the image is very fluid.
I think when the 360hz TNs come out everyone will go there.
Ps I did the tests you indicated (without Mbr) and I have not noticed practically any difference between Omen and Acer, both set at 240hz of course.
I think 2k is the perfect resolution today to play and have feast for the eyes, especially if you want to play a bit of everything, certainly better than full hd.sk1p wrote: ↑19 Nov 2021, 01:35According to this review, 2k IPS's panels are faster with default overdrive than current 1080 IPS's, percentage transition within refresh window 77-90% and I don't see any overshoot with xv272ux normal overdrive: https://tftcentral.co.uk/reviews/dell_alienware_aw2721dIIISLIDEIII wrote: ↑17 Nov 2021, 23:10
The "problem" I have with 2k when I go to use them on a shooter, is not so much the response times or the input lag, but the dimensions, for me 27 is really gigantic, I have to move it to the back of my desk and I would like to move it away again but I have no more space, this is the only limit for me.
If they did a 24 inch 2k I would switch to that immediately.
Why do them both at 240 Hz? The point was to see the difference 150 Hz can make.IIISLIDEIII wrote: ↑20 Nov 2021, 07:45Ps I did the tests you indicated (without Mbr) and I have not noticed practically any difference between Omen and Acer, both set at 240hz of course.
Also, did you turn on max brightness on the Acer? When I was trying MBR extreme, the panel seemed very bright. Actually brighter than the settings I currently use with MBR off.
yes, maximum brightness always active, but always 220nits are.lizardpeter wrote: ↑20 Nov 2021, 12:00Why do them both at 240 Hz? The point was to see the difference 150 Hz can make.IIISLIDEIII wrote: ↑20 Nov 2021, 07:45Ps I did the tests you indicated (without Mbr) and I have not noticed practically any difference between Omen and Acer, both set at 240hz of course.
I'm probably used to bad eyes, but where you say you see well it's almost dark for me
you told me you play without mbr, but if that's enough clear for you, why you don't use mbr?
IIISLIDEIII, which panel is your 2546k? This can be found in the service menu. To enter it, you need to turn off the monitor and turn it on while keeping the joystick pressed.
monitors: TN ACER 1916 (75Hz)>TN ACER 1917 (75Hz)>XL2540K (240Hz)>IIYAMA MASTER VISION PRO 451 (CRT 160 Hz)>xl2546k>omen x 25>24g2zu>xv252qf
after I look at it.
Why do you ask me that ? are there any differences based on production?
This may be a dumb question but something I am wondering with regards to 240hz vs 390hz. If two monitors with the same pixel technology produce the same response times at their max refresh, one being 240 and the other 390, would the higher refresh rate monitor produce a blurrier image?
I don’t use MBR because I’ve tried it on and off and only see a major difference when looking at UFO tests. In actual games, I noticed next to no improvement. Plus MBR on does increase latency very slightly, and I kind of value the fact that the monitor has the lowest input lag on the market. Turning MBR or GSYNC on puts it at the same level as the ASUS 360 Hz monitor according to the tests I have seen. I’ll be interested to see RTINGS review though. It’s about to win their monitor vote to be reviewed.IIISLIDEIII wrote: ↑20 Nov 2021, 12:32you told me you play without mbr, but if that's enough clear for you, why you don't use mbr?
I think if you use mbr active for 1 full day of play when you try to turn it off you can feel the difference, the same happened to me with dyac, in the flick the objects in the background are a little less blurry.lizardpeter wrote: ↑20 Nov 2021, 14:55I don’t use MBR because I’ve tried it on and off and only see a major difference when looking at UFO tests. In actual games, I noticed next to no improvement. Plus MBR on does increase latency very slightly, and I kind of value the fact that the monitor has the lowest input lag on the market. Turning MBR or GSYNC on puts it at the same level as the ASUS 360 Hz monitor according to the tests I have seen. I’ll be interested to see RTINGS review though. It’s about to win their monitor vote to be reviewed.IIISLIDEIII wrote: ↑20 Nov 2021, 12:32you told me you play without mbr, but if that's enough clear for you, why you don't use mbr?
