Hello all, i want buy New monitor, i look tn for Best performance. Now i have Xl2546 non k.
I want switch to newest tn panel, what the tn monitor now the Best? I love pubg, cs, dota,and solo games, i no need ips panel, i have 2k monitor for solo gaming on ips panel.
What the Best tn monitor
Xl 2546
Re: What the Best tn monitor
Your signature mentions the XL2546, one of the best TN panels available.
Just so you know -- several models of newer 2020-and-newer 240Hz+ IPS has similar performance to TN nowadays.
IPS is beginning to be increasingly used in esports too.
Keep your current monitor. Getting any new TN wouldn't really feel as proper upgrade motion blur wise. Maybe wait for something new to come out if u really need it. There are rumors of new 360Hz TN panels.
OK, thanks, I thought maybe it should be changed to the k version
Xl 2546
Maybee xg2431? But when use strobe, brightness lower than zowie ((((
Xl 2546
Do you even use the monitor at maximum brightness?
viewtopic.php?p=75670#p75670
But again, you don't need new monitor.
If you have any XL2546 model, keep it. The K isn't worth upgrading a non-K XL2546 for.
I use 2546 with 100 brightness, gamma 2,and contrast 65Discorz wrote: ↑06 Dec 2021, 03:29Do you even use the monitor at maximum brightness?
Xl 2546
OK, thx, waiting New 360 hz zowieChief Blur Buster wrote: ↑06 Dec 2021, 03:33If you have any XL2546 model, keep it. The K isn't worth upgrading a non-K XL2546 for.
Xl 2546
