Hello everyone so i have a ASUS VX248H monitor and these days i've been wanting to modify the EDID of the monitor via Linux, but as i've watched alot of tutorials and i already understood how to do it but in every tutorial i've watched they say that i need to enable EDID Write permission via service menu. But the problem it's that i don't have any EDID option in the service menu, so i did further research and i found that there are some softwares that can control monitor "hidden features" via DDC/CI so as i use this screen for console gaming im wondering if any changes that i could done via DDC/CI will still active even if i unplug the monitor from the PC and plug it back in my console.
I want to use SoftMCCS to do this changes on the monitor.
So my 2 main questions are:
1: if i change any setting via SoftMCCS (DDC/CI) and unplug it from the PC will the configuration still be saved even if i plug the monitor on a console?
2: Does anyone knows if this monitor (ASUS VX248H) supports EDID Rewriting ? As i don"t wanna try it without being sure because it can cause a monitor Brick.
Thanks
ASUS VX248H
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
