Fastest 240hz tn panel
Posted: 08 Jan 2022, 01:18
Looking for what on paper is the fastest 240hz tn panel 1080p
Who you gonna call? The Blur Busters! For Everything Better Than 60Hz™
https://forums.blurbusters.com/
masterblaster wrote: ↑09 Jan 2022, 01:58xl2546k is definitely not the fastest... At least not in terms of input lag and response times.
KD25F, XF252Q and the Omen X25 (non F)ysenojftw wrote: ↑09 Jan 2022, 02:20masterblaster wrote: ↑09 Jan 2022, 01:58xl2546k is definitely not the fastest... At least not in terms of input lag and response times.
Which is the fastest in the 240hz tn non strobed?
I got my omen x 25. And in my opinion it is slower than the 2540k or 2546k panel (same). Sometimes it seems to me that I can see blur on the omen, with overdrive 3 (while the artifacts of the corona are noticeable), although it may be due to the terrible pixel inversion that my copy suffers from (the worst pixel inversion that I have seen), the picture loses clarity at such moments due to pixel shift. I could be wrong, and there may be blur too. On a premium ama, I almost did not see artifacts corona, on omen overdrive 3 ghosting is much more noticeable, with overdrive level 4 it is unrealistic to play, they are not only at level 2, but there the picture seems more often blurry. I saw no benefit in g-sync and I think that perhaps the "f" version is no worse, since rings tested it. Having tried Omen and 2540k-2546k I recommend exclusively the Benq. The panel is faster and the monitor is objectively better in most aspects. The Omen liked the viewing angles and the relatively good initial color setting, but the Benq easily adjusts better. Also, my copy of Omena has 2 broken pixels (one consists of dark subpixels, the other is frozen red) and maybe I had no luck with the panel. However, in tests ufo and in games, I find an advantage benq. This is the most versatile monitor for all shooters, I think that the hype bank is justified in this case.
