Hi,
I have seemingly three identical Macbook Pro 15" 2012 (A1286) with the high-res display (silver bezzles 1680x1050) next to each other. In 2012 Apple made these monitors availble:
Glossy Widescreen Display (1400x900)
Hi-Res Glossy Widescreen Display (1680x1050)
Hi-Res Antiglare Widescreen Display (16580x1050)
Retina display
I noticed while comparing them side by side that Macbook Pro #1 displays more screen/image/text than the other two while running the exact same 1680x1050 resolution. Also the colors look a bit crisper but at the same time a bit more matte on Macbook Pro #1 compared to #2 and #3. I think its due to that Macbook Pro #1 has 32 bit color and the other two panels have 24 bit color.
I snapped these for cheap on an auction used so Im not sure if they had any previous screen replacements for example. I can only afford to keep one, so I want to keep the best one naturally
Does anybody know if the 32 bit color panel is an aftermarket one?
I ran this command in terminal and noticed a differencence in :
« ioreg -lw0 | grep "EDID" | sed "/[^<]*</s///" | xxd -p -r | strings -6 »
Macbook Pro #1:
Manufacture date: 2013-05-13
LTN154MT07
Color LCD
4C31801768P5A
LTN154MT07
Color LCD
From "MacOS System report:
LCD
1680 x 1050
32-bits color (ARGB8888)
Macbook Pro #2:
Manufacture date: 2012-10-29.
LTN154MT07
COLOR LCD
4C23400398P5A
LTN154MT07
LCD
1680 x 1050
24-bit color (ARGB8888)
Macbook Pro #3:
I wish I could post anything here, but atm I am having issues getting it to boot into MacOS. I can only access Windows so have a separate issue with this one.
Detirmine display panel on monitor macbook pro help
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
