Hey guys,
Well, it seems I am back on this Forums, as I loved the G-Sync series research articles and I believe i could get good info here.
My problem is that whenever I play game like Valorant (Multiplayer, FPS Shooter game), my FPS fluctuate really by a lot (180-300 FPS). And I believe I should be able to hold steady 300 FPS with following settings and my HW:
MY HW:
- i9-9900K
- RTX 2080
- 16 GB RAM (3200 Hz speed)
- 1 TB NVMe (Samsung)
- Monitor: Alienware 240 Hz (1080p)
My Valorant Settings:
- FPS cap to 300
- All Graphic settings are set to LOW
- They have option for Multi-Threaded Rendering, which I set to ON
- They have option for NVIDIA Reflex (Low Latency) which I set to ON (there's an option to also ON + Boost, but I do not set that)
- I have also set all NVIDIA Control Panel settings to OFF / LOW whever possible, and PREFFER MAXIMUM PERFORMANCE
Results are: FPS fluctuates between 180-300 FPS. Benchmarks show that with this config I shuold be able to hit 500 or more. But I'd like at least 300 or something above 240, to match my monitor refresh rate.
Here are some HW Stats after playing Deathmatch (most demanding Game Mode where FPS is expected to be lower):
LINK: https://ibb.co/fqbSmTH
From what I can at least understand is, to me it looks like GPU and CPU are not well utilized during gameplay? GPU was mostl 0-1% and CPU cca 20%.
Does anyone have any ideas what else could I try?
Thank you.
FPS fluctuating too much
Return to “General — Displays, Graphics & More”
Jump to
- The Main Lobby
- ↳ General — Displays, Graphics & More
- ↳ News / Rumors / Conventions
- ↳ Input Lag / Display Lag / Network Lag
- ↳ Display Comfort — Eyestrain / Headaches / Motionsick
- Everything Better Than 60Hz™
- ↳ Eliminating Motion Blur — LightBoost / ULMB / ELMB / DyAc
- ↳ OLED Displays
- ↳ G-SYNC
- ↳ FreeSync
- ↳ Game Consoles — XBOX and PlayStation — ONE / Series S / Series X / PS5
- ↳ BENQ Zowie Tweaking — Strobe Utility / Blur Reduction / DyAc
- ↳ Display Overclocking
- The Laboratory
- ↳ Test UFO Motion Tests
- ↳ Area 51: Display Science, Research & Engineering
- ↳ Software Developers / Low-Lag Code / Game Programming
- ↳ Pursuit Camera Testing of Display Motion Blur
- ↳ High Frame Rate Video (HFR, UltraHFR, 120fps, 240fps, 1000fps)
- The Cafeteria
- ↳ Offtopic Lounge
- ↳ Niche Issues Affecting Latency — Electrical, Interference, EMI, Unexpected Causes, etc.
- ↳ Forum System / Registration / Suggestions
